Seagate 2TB Barracuda ST2000DM008 7200 RPM SATA 600 3.5" Hard Drive
Quicklinx: F47RWS00 Mfr#: ST2000DM008
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
Spin Speed (rpm): 7200rpm
38 In Stock
£39.96 ex VAT
£47.95 inc VAT
Get an HDD for all your PC needs bring you outstanding excellence in personal computing.
  • Versatile
  • Advanced power
    Advanced power helps save energy without sacrificing performance.
Seagate Barracuda ST2000DM008 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Halogen Free, Seagate OptiCache technology, Seagate AcuTrac technology, Seagate SmartAlign technology, Hot-Plug Support, Worldwide Name (WWN), TGMR recording technology, S.M.A.R.T.
101.6 mm x 146.99 mm x 20.17 mm
415 g
2 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
20.17 mm
415 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Seek Time
8.5 ms (average)
Track-to-Track Seek Time
1 ms
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
RoHS
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
80 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
350 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
3 g @ 22-350 Hz
Form Factor: 3.5
Type: Hard drive
Capacity: 2TB
Brand: Seagate
