Seagate 2TB Barracuda ST2000DM008 7200 RPM SATA 600 3.5" Hard Drive
Quicklinx: F47RWS00 Mfr#: ST2000DM008
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
Spin Speed (rpm): 7200rpm
8 on order, delivery delayed
£39.57 ex VAT
£47.48 inc VAT
Get an HDD for all your PC needs bring you outstanding excellence in personal computing.
  • Versatile
  • Advanced power
    Advanced power helps save energy without sacrificing performance.
Seagate Barracuda ST2000DM008 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Halogen Free, Seagate OptiCache technology, Seagate AcuTrac technology, Seagate SmartAlign technology, Hot-Plug Support, Worldwide Name (WWN), TGMR recording technology, S.M.A.R.T.
101.6 mm x 146.99 mm x 20.17 mm
415 g
2 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
20.17 mm
415 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Seek Time
8.5 ms (average)
Track-to-Track Seek Time
1 ms
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
RoHS
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
80 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
350 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
3 g @ 22-350 Hz
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: F47R 051069
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £17.62
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Form Factor: 3.5
Type: Hard drive
Capacity: 2TB
Brand: Seagate
Stock Status: On order, delivery delayed
Stock Status: Used Stock
