The company that has provided the world with product innovation over 12 generations of desktop drives has turned its focus to the increasing customer needs for low-power drives. Meet the Seagate Barracuda LP family, the low-power drive with rock-solid performance and whisperquiet, super-cool operation.
Best-Fit Applications
- Direct Attached Storage devices-USB/FireWire/eSATA
- Network Attached Storage devices and Windows storage servers
- Eco friendly PCs
- High-capacity desktop storage
Barracuda® Green drives from Seagate save you time. Available now with SATA 6Gb/s interface and 64MB cache and combined with the industry's only 5900-RPM spin speed, you can be sure you're getting the best performance in the green-power drive category.
Seagate SmartAlign™ technology simplifies your transition to the Advanced Format (AF), 4K standard. There is no need for time-consuming integration utilities required by similar AF drives.
Key Features and Benefits
- A unique 5900-RPM speed delivers the fastest-performance eco friendly drive available.
- Seagate SmartAlign technology allows you to get all the benefits of the new Advanced Format 4K sector standard without any hassle-no utilities, no extra steps.
- The SATA 6Gb/s interface and 64MB cache maximize performance.
- Low power consumption combined with leadership in the use of recycled materials means you don't have to sacrifice environmental stewardship for performance.
- Cool, quiet operation
- Seagate Barracuda Green ST2000DL003 - hard drive - 2 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 2 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 5900 rpm
- Native Command Queuing (NCQ)
- 10.2 cm x 14.7 cm x 2.6 cm
- 0.64 kg
- 2-year warranty
- Capacity
- 2 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- Bytes per Sector
- 4096
- 10.2 cm
- 14.7 cm
- 2.6 cm
- 0.64 kg
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 144 MBps
- Seek Time
- 12 ms (average)
- Average Latency
- 4.16 ms
- Spindle Speed
- 5900 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Start / Stop Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Limited warranty - 2 years
- 0 °C
- 60 °C
- Shock Tolerance
- 80 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
