The Seagate Enterprise Performance 10K HDD is an ideal 1.2 TB hard drive for mission critical applications. It delivers best-in-class mission critical random performance, highest capacities and the low power that data centers need to meet demanding service level agreements and to keep up with data growth and reduce IT operating costs.
 - Seagate Exos 10E2400 ST2400MM0129 - hybrid hard drive - 2.4 TB - SAS 12Gb/s
 - Hybrid hard drive - internal
- Capacity
 - 2.4 TB
- Flash Memory Capacity
 - 16 GB
- NAND Flash Memory Type
 - Enterprise multi-level cell (eMLC)
- Form Factor
 - 2.5" SFF
- Interface
 - SAS 12Gb/s
- Data Transfer Rate
 - 1.2 GBps
- Buffer Size
 - 256 MB
- Spindle Speed
 - 10000 rpm
 - PowerChoice, Protection Information (PI), Seagate RAID Rebuild, Instant Secure Erase (ISE), advanced format 512e, advanced format 4Kn, Intelligent NAND Endurance Management, Seagate Fast Format
 - 70.1 mm x 100.45 mm x 15 mm
 - 230 g
 - 5-year warranty
- Capacity
 - 2.4 TB
 - 16 GB
- Form Factor
 - 2.5" SFF
- Interface
 - SAS 12Gb/s
- Buffer Size
 - 256 MB
 - 70.1 mm
 - 100.45 mm
 - 15 mm
 - 230 g
Performance
- Drive Transfer Rate
 - 1.2 GBps (external)
- Internal Data Rate
 - 270 MBps
- Average Latency
 - 2.9 ms
- Spindle Speed
 - 10000 rpm
Reliability
- Non-Recoverable Errors
 - 1 per 10^16
Expansion & Connectivity
 - 1 x SAS 12 Gb/s
- Compatible Bay
 - 2.5" SFF
- Power Consumption
 - 8.5 Watt (active) , 4.8 Watt (idle)
 - ISO/IEC 27040:2015, NIST SP800-88
 - Limited warranty - 5 years
 - 5 °C
 - 55 °C
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Shock Tolerance (operating)
 - 40 g @ 11 ms
- Shock Tolerance (non-operating)
 - 400 g @ 2 ms
- Vibration Tolerance (operating)
 - 0.5 g @ 0-500 Hz
- Vibration Tolerance (non-operating)
 - 3 g @ 0-500 Hz
