Instantly expand the capacity of the powerful gaming experience Xbox has ever created with the Seagate Storage Expansion Card for Xbox Series X/S. Effortlessly compatible with the Xbox Velocity Architecture, experience the fastest load times and most dynamic worlds - with improved performance optimized for Xbox Series X games spanning every Xbox generation. Play at home or take it to a friend's house; peak performance is now at your fingertips.
- SEAMLESS GAMEPLAY Designed in partnership with Xbox to seamlessly play Xbox Series X|S games from the internal SSD or the expansion card without sacrificing graphics, latency, load times, or framerates
- HIGH CAPACITY 1TB of storage increases the overall capacity of the Xbox Series X|S—collect thousands of games across four generations of Xbox without sacrificing performance
- EXCLUSIVE TO XBOX The only available expansion card that replicates the Xbox Velocity Architecture —providing faster load times, richer environments, and more immersive gameplay
- QUICK RESUME Switch between multiple titles in seconds—directly from the internal SSD or the expansion card
- WARRANTY Enjoy long-term peace of mind with the included 3-year limited warranty
Expansive storage
With a 1 TB capacity, this Seagate Storage Expansion Card offers ample space for storing large files, high-resolution images, and extensive game libraries on a solid state drive, ensuring quick access and reliable performance. -
High-speed connectivity
Equipped with a PCIe 4.0 x2 interface, the Seagate Storage Expansion Card provides fast data transfer rates, making it suitable for computing environments and enhancing the overall system responsiveness. -
Easy integration
Designed for seamless compatibility with the Seagate Expansion Card slot, this interface adapter ensures a straightforward setup process, allowing users to expand their storage capacity without the hassle of complex installations.
- Seagate Storage Expansion Card STJR1000400 - interface adapter - PCIe 4.0
- Interface adapter - external
- Hard Drive
- 1 x 1 TB solid state
- Interface
- PCIe 4.0
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 1
- 3.16 cm x 5.295 cm x 0.78 cm
- 30 g
- 3-year warranty
- Designed For
- Xbox Series S, Xbox Series X
Storage Controller
- Interface
- PCIe 4.0
- Supported Devices
- Solid state drive
- 1
- 1 x PCIe 4.0 x2
- Connections
- 1 x Seagate Expansion Card
Hard Drive
- Solid state
- Installed Qty
- 1
- Capacity
- 1 TB
- Supports NVM Express
- Limited warranty - 3 years
- 3.16 cm
- 5.295 cm
- 0.78 cm
- 30 g
- Shipping Width
- 7.62 cm
- Shipping Depth
- 13.97 cm
- Shipping Height
- 5.08 cm
- Shipping Weight
- 730 g
- Designed For
