Seagate 1TB Storage Expansion Card for Xbox Series XS SSD
Quicklinx: G9MTWS00 Mfr#: STJR1000400
Form Factor: PCI Express
Capacity: 1TB, 1TB
Interface: U.2 PCIe 3.1 x4 (NVMe)
Type: External hard drive
Hurry, only 1 left in stock!
£191.66 ex VAT
£229.99 inc VAT
Instantly expand the capacity of the powerful gaming experience Xbox has ever created with the Seagate Storage Expansion Card for Xbox Series X/S. Effortlessly compatible with the Xbox Velocity Architecture, experience the fastest load times and most dynamic worlds - with improved performance optimized for Xbox Series X games spanning every Xbox generation. Play at home or take it to a friend's house; peak performance is now at your fingertips.
  • SEAMLESS GAMEPLAY Designed in partnership with Xbox to seamlessly play Xbox Series X|S games from the internal SSD or the expansion card without sacrificing graphics, latency, load times, or framerates
  • HIGH CAPACITY 1TB of storage increases the overall capacity of the Xbox Series X|S—collect thousands of games across four generations of Xbox without sacrificing performance
  • EXCLUSIVE TO XBOX The only available expansion card that replicates the Xbox Velocity Architecture —providing faster load times, richer environments, and more immersive gameplay
  • QUICK RESUME Switch between multiple titles in seconds—directly from the internal SSD or the expansion card
  • WARRANTY Enjoy long-term peace of mind with the included 3-year limited warranty
  • Expansive storage
    With a 1 TB capacity, this Seagate Storage Expansion Card offers ample space for storing large files, high-resolution images, and extensive game libraries on a solid state drive, ensuring quick access and reliable performance.
  • High-speed connectivity
    Equipped with a PCIe 4.0 x2 interface, the Seagate Storage Expansion Card provides fast data transfer rates, making it suitable for computing environments and enhancing the overall system responsiveness.
  • Easy integration
    Designed for seamless compatibility with the Seagate Expansion Card slot, this interface adapter ensures a straightforward setup process, allowing users to expand their storage capacity without the hassle of complex installations.
Seagate Storage Expansion Card STJR1000400 - interface adapter - PCIe 4.0
Interface adapter - external
Hard Drive
1 x 1 TB solid state
PCIe 4.0
Supported Devices
Solid state drive
Max Storage Devices Qty
1
3.16 cm x 5.295 cm x 0.78 cm
30 g
3-year warranty
Xbox Series S, Xbox Series X
Storage Controller
PCIe 4.0
Supported Devices
Solid state drive
1
1 x PCIe 4.0 x2
1 x Seagate Expansion Card
Hard Drive
Solid state
Installed Qty
1
1 TB
Supports NVM Express
Limited warranty - 3 years
3.16 cm
5.295 cm
0.78 cm
30 g
Shipping Width
7.62 cm
Shipping Depth
13.97 cm
Shipping Height
5.08 cm
Shipping Weight
730 g
Capacity: 1TB
Capacity: 1TB
Brand: Seagate
