Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
Reliable performance
Designed for 24x7 operation, the Seagate SkyHawk Surveillance HDD ensures constant availability and reliability for your surveillance system. Its ImagePerfect firmware is specifically tailored to minimize dropped frames and downtime, making it suitable for security-intensive applications. -
Efficient storage solution
With a 1 TB capacity and a data transfer rate of 600 MBps, this hard drive meets the demands of high-resolution video recording and playback. The Serial ATA-600 interface provides a stable and fast connection, enhancing the efficiency of data retrieval and storage operations. -
Durable design
Built to withstand the rigors of continuous operation, the Seagate SkyHawk Surveillance HDD operates within a wide temperature range from 0 °C to 70 °C. Its high MTBF of 1,000,000 hours signifies a long-lasting and reliable storage solution for surveillance systems.
- Seagate SkyHawk Surveillance HDD ST1000VX005 - hard drive - 1 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 1 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 5900 rpm
- 24x7 availability, ImagePerfect firmware
- 101.85 mm x 146.99 mm x 20.2 mm
- 415 g
- 3-year warranty
- Capacity
- 1 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- 101.85 mm
- 146.99 mm
- 20.2 mm
- 415 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 180 MBps
- Spindle Speed
- 5900 rpm
Reliability
- MTBF
- 1,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^14
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5"
- Power Consumption
- 1.8 watt (start) ¦ 5.6 watt (active) ¦ 4 watt (idle) ¦ 0.5 watt (sleep) ¦ 0.5 watt (standby)
- Limited warranty - 3 years
- 0 °C
- 70 °C
