Seagate 1TB SkyHawk 3.5" SATA 6Gb/s 64MB Surveillance Hard Drive
Quicklinx: CH06WS00 Mfr#: ST1000VX005
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 1TB, 1TB
Spin Speed (rpm): 5900rpm
17 In Stock
£39.09 ex VAT
£46.90 inc VAT
Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
  • Reliable performance
    Designed for 24x7 operation, the Seagate SkyHawk Surveillance HDD ensures constant availability and reliability for your surveillance system. Its ImagePerfect firmware is specifically tailored to minimize dropped frames and downtime, making it suitable for security-intensive applications.
  • Efficient storage solution
    With a 1 TB capacity and a data transfer rate of 600 MBps, this hard drive meets the demands of high-resolution video recording and playback. The Serial ATA-600 interface provides a stable and fast connection, enhancing the efficiency of data retrieval and storage operations.
  • Durable design
    Built to withstand the rigors of continuous operation, the Seagate SkyHawk Surveillance HDD operates within a wide temperature range from 0 °C to 70 °C. Its high MTBF of 1,000,000 hours signifies a long-lasting and reliable storage solution for surveillance systems.
Seagate SkyHawk Surveillance HDD ST1000VX005 - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5900 rpm
24x7 availability, ImagePerfect firmware
101.85 mm x 146.99 mm x 20.2 mm
415 g
3-year warranty
1 TB
3.5"
SATA 6Gb/s
Buffer Size
64 MB
101.85 mm
146.99 mm
20.2 mm
415 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
180 MBps
Spindle Speed
5900 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5"
Power Consumption
1.8 Watt (start) , 5.6 Watt (active) , 4 Watt (idle) , 0.5 Watt (sleep) , 0.5 Watt (standby)
Limited warranty - 3 years
70 °C
Form Factor: 3.5
Type: Hard drive
Capacity: 1TB
Capacity: 1TB
Brand: Seagate
