Huge capacity in a thin lightweight design, the Seagate mobile HDD stores thousands of photos and songs or long hours of high-definition video. The Mobile HDD has some of the very advanced features. It is ideally suited for traditional laptops, convertible and detachable storage, slim consumer electronics devices, helping to protect your sensitive data.
Compatibility and flexibility
The mobile HDD works with SATA 6Gb/s and SATA 3Gb/s designs. This slim, high-performance HDD integrates easily. Drop in 1 TB without the weight of traditional laptop drives. -
High areal density comes with quiet operation and excellent shock resistance
The mobile HDD enables high areal density in a small form factor. The drive additionally performs operations very quietly and has advanced shock resistance.
- Seagate Mobile ST1000LM035 - hard drive - 1 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 1 TB
- Form Factor
- 2.5" SFF
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 5400 rpm
- QuietStep, Halogen Free, Ramp Load, advanced format 512e, shingled magnetic recording (SMR)
- 69.85 mm x 100.35 mm x 7 mm
- 90 g
- 2-year warranty
- Designed For
- Intel Next Unit of Computing 12 Pro Kit - NUC12WSHi3
- Capacity
- 1 TB
- Form Factor
- 2.5" SFF
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 4096
- 69.85 mm
- 100.35 mm
- 7 mm
- 90 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 100 MBps
- Seek Time
- 13 ms (average)
- Spindle Speed
- 5400 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5" SFF
- Power Consumption
- 1.6 Watt (seek) , 0.45 Watt (idle)
- RoHS
- Limited warranty - 2 years
- 0 °C
- 60 °C
- Shock Tolerance (operating)
- 400 g @ 2 ms
- Shock Tolerance (non-operating)
- 1000 g @ 1 ms
- Designed For
