The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
- Seagate IronWolf ST1000VN002 - hard drive - 1 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 1 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 5900 rpm
- Halogen Free, NAS compatible, 24x7 availability, Dual-Plane Balance, Error Recovery Control
- 101.6 mm x 146.99 mm x 20.17 mm
- 415 g
- 3-year warranty
- Capacity
- 1 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- 101.6 mm
- 146.99 mm
- 20.17 mm
- 415 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 180 MBps
- Spindle Speed
- 5900 rpm
Reliability
- MTBF
- 1,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 3.6 Watt (active) , 2.5 Watt (idle) , 0.8 Watt (standby) , 0.8 Watt (sleep)
- Limited warranty - 3 years
- 5 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 80 g @ 2 ms
- Shock Tolerance (non-operating)
- 300 g @ 2 ms
