Seagate 1TB Game Drive for Xbox SSD
Quicklinx: FDXBWS00 Mfr#: STHB1000401
Form Factor: 2.5
Capacity: 1TB, 1TB
Interface: USB 3.0
Type: External hard drive
£127.43 ex VAT
£152.91 inc VAT
Game Drive for Xbox SSD is Seagate's premium external solid state drive, designed with peak gaming performance in mind. This game drive uses external flash SSD storage to accelerate installation and load times for your Xbox games.
  • Enhanced portability
    The Seagate Game Drive for Xbox is designed with portability in mind, featuring a compact form factor that makes it easy to take your entire game library on-the-go. Its external, portable design ensures you can play your favorite games on any Xbox console without the need for installation.
  • Rapid data transfer
    Equipped with a SuperSpeed USB cable and supporting USB 3.0 interface, the Seagate Game Drive offers interface speeds up to 5.0 Gbps. This means significantly reduced waiting times when transferring large game files, ensuring you spend more time playing and less time waiting.
  • Ample storage capacity
    With a 1 TB capacity, this hard drive provides ample space for storing numerous video games, downloadable content, and patches. It eliminates the worry of running out of storage space and allows for a comprehensive game collection.
Seagate Game Drive for Xbox STHB1000401 - SSD - 1 TB - USB 3.0
Solid state drive - external (portable)
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Power Source
USB bus
Enclosure Colour
93.45 mm x 79 mm x 9.1 mm
84 g
Worldwide
3-year warranty
1 TB
USB 3.0
93.45 mm
79 mm
9.1 mm
84 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
1 x USB 3.0 cable - external - 46 cm
Enclosure Colour
Worldwide
Limited warranty - 3 years
Form Factor: 2.5
Capacity: 1TB
Capacity: 1TB
Interface: USB 3.0
Brand: Seagate
