Game Drive for Xbox SSD is Seagate's premium external solid state drive, designed with peak gaming performance in mind. This game drive uses external flash SSD storage to accelerate installation and load times for your Xbox games.
Enhanced portability
The Seagate Game Drive for Xbox is designed with portability in mind, featuring a compact form factor that makes it easy to take your entire game library on-the-go. Its external, portable design ensures you can play your favorite games on any Xbox console without the need for installation. -
Rapid data transfer
Equipped with a SuperSpeed USB cable and supporting USB 3.0 interface, the Seagate Game Drive offers interface speeds up to 5.0 Gbps. This means significantly reduced waiting times when transferring large game files, ensuring you spend more time playing and less time waiting. -
Ample storage capacity
With a 1 TB capacity, this hard drive provides ample space for storing numerous video games, downloadable content, and patches. It eliminates the worry of running out of storage space and allows for a comprehensive game collection.
 - Seagate Game Drive for Xbox STHB1000401 - SSD - 1 TB - USB 3.0
 - Solid state drive - external (portable)
- Capacity
 - 1 TB
- Interface
 - USB 3.0
- Data Transfer Rate
 - 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Power Source
 - USB bus
- Enclosure Colour
 - Black
 - 93.45 mm x 79 mm x 9.1 mm
 - 84 g
- Localisation
 - Worldwide
 - 3-year warranty
- Capacity
 - 1 TB
- Interface
 - USB 3.0
 - 93.45 mm
 - 79 mm
 - 9.1 mm
 - 84 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
 - 1 x USB 3.0
- Power Source
 - USB bus
- Cables Included
 - 1 x USB 3.0 cable - external - 46 cm
- Enclosure Colour
 - Black
- Localisation
 - Worldwide
 - Limited warranty - 3 years
