The Barracuda family has earned awards and accolades around the globe. This is because Seagate has demonstrated a commitment to introduce technologies that allow people to work faster, do more, and feel great about making an investment in proven technology. And, for those who want the biggest, high performance drive available, the Barracuda choice is without peer.
- Seagate Barracuda ST1000DM010 - hard drive - 1 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 1 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Halogen Free, Seagate OptiCache technology, Seagate SmartAlign technology, Hot-Plug Support, Worldwide Name (WWN), TGMR recording technology, S.M.A.R.T.
- 101.6 mm x 146.99 mm x 20.17 mm
- 400 g
- 2-year warranty
- Capacity
- 1 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- Bytes per Sector
- 4096
- 101.6 mm
- 146.99 mm
- 20.17 mm
- 400 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 210 MBps
- Seek Time
- 8.5 ms (average)
- Track-to-Track Seek Time
- 1 ms
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Start / Stop Cycles
- 50,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5"
- Power Consumption
- 2 Watt (start) , 5.3 Watt (active) , 4.6 Watt (idle) , 0.94 Watt (standby) , 0.94 Watt (sleep)
- RoHS, China RoHS
- Limited warranty - 2 years
- 0 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- 5 - 95% (non-condensing)
- Shock Tolerance (operating)
- 80 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 350 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.5 g @ 22-350 Hz
- Vibration Tolerance (non-operating)
- 3 g @ 22-350 Hz
