The Seagate Backup Plus Slim portable drive simplifies backup for consumers who want to help protect their entire digital life locally, in the cloud, from mobile devices or from social networks. The slim, metal design allows you to slide the drive into your pocket, purse or backpack and carry it with you. Via the Seagate Dashboard, use the Protect function to set up a one-click plan or schedule your automatic local backup. Keep multiple copies of your files in case disaster strikes. Install the free Seagate Mobile Backup app on an iOS or Android mobile device to back up all of the pictures and videos from the device to the drive or the cloud. Back up mobile devices via a WiFi connection while at home, or use services like Dropbox or Google Drive while on-the-go, away from home.
With the Save feature, user-generated content can be backed up from your favorite social networks. Capture a memory, post it on a social networking site, and let the Seagate Dashboard automatically back up any content posted, even photos that you are tagged in.
The Share feature allows multiple files to be uploaded to social networks at once from your computer. Simply select files to upload, choose where to post them and even add comments. Managing your social profile has never been easier.
Install the pre-loaded NTFS driver for Mac, and use the drive interchangeably between Windows and Mac computers without reformatting the drive.
Back up from your mobile devices
Use the Seagate Mobile Backup App to easily back up photos and videos on the go directly from your mobile devices to Backup Plus Slim Portable Drive. -
Back up and protect photos, videos and more - automatically
Choose from two easy backup options in the Seagate Dashboard - scheduled or continuous. -
Do more with social networks
Don't risk losing those great pics you've posted online. The Backup Plus Slim Portable Drive finally bridges the gap between your online life and the rest of your life, letting you automatically back up your favorite memories from Facebook and Flickr. You can even share new videos to your YouTube account.
- Seagate Backup Plus Slim STEH1000200 - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Automatic backup
- Power Source
- USB bus
- Enclosure Colour
- Platinum
- 76 mm x 9.6 mm x 113.5 mm
- 135 g
- Localisation
- EMEA
- 2-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.0
- Automatic backup
- 76 mm
- 9.6 mm
- 113.5 mm
- 135 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Software Included
- Driver, Seagate Dashboard
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.7 or later
- Cables Included
- 1 x USB 3.0 cable - external - 45.72 cm
- Enclosure Colour
- Platinum
- Localisation
- EMEA
- Limited warranty - 2 years
