Store and Backup your entire digital life from your PC, Mac and mobile devices.
Backup Plus Slim is an easy way to protect and share your digital life. Ready to go with up to 2TB of storage space for your most important files, the sleek and protective metal finish is available in classic black, silver, red or blue.
High-speed USB 3.0 and 2.0 connectivity offers plug-and-play functionality on your PC without the need of an external power supply.
Install the NTFS driver for Mac, and you can use the drive interchangeably between Windows and Mac computers without reformatting.
It's your life. Keep it together.
The included Seagate Dashboard software provides you with the tools to backup your data from local PCs, mobile devices, cloud storage providers and even your social media accounts.
Backup of your files can be scheduled to run continuously, at specific times, or on-demand using the Dashboard software's one-click functionality.
No matter where your data usually resides, your Seagate Backup Plus portable drive helps you keep all your files organised and backed-up.
Back up your mobile devices
Save user-generated photos and videos, even tagged content, directly from your social networks - automatically. You can upload multiple photos and videos directly from the drive to your favourite social media too.
Instal the free Seagate Mobile Backup app on an iOS or Android mobile device to back up all of the pictures and videos to your external drive, and free up precious space on your device.
Mac and Windows Ready
It's easy to use your Backup Plus Portable Drives interchangeably on PC and Mac computers -- without needing to reformat. Just instal NTFS drivers on your Mac and you're good to go.
What's in the box?
- Seagate Portable Drive
- Seagate Dashboard Software (pre-loaded)
- NTFS Driver for Mac (pre-loaded)
- USB 3.0 Interface Adapter
- USB 3.0 Cable
- User Documentation
Protect photos, videos, and more-on the go
Life is full of amazing moments you want to remember forever. The Backup Plus portable drive goes where you go, providing easy, Plug-and-Play backups. So you know that no matter where "life happens, " your memories are always protected. -
Save your social life with a click
Think of how many photos you've shared on Facebook or Flickr. With Backup Plus, you can easily download them right to your drive, so even more of your life is safe and sound. -
Share your favorite moments instantly
With Backup Plus, your memories aren't "trapped" in your drive. Just a click lets you share photos and videos to Facebook and Flickr or YouTube right from your Backup Plus drive. -
Upgrade your connectivity in a snap
Getting a new computer with Thunderbolt technology or USB 3.0? Not a problem. Changing your connectivity is as easy as plugging in a new adapter. So even when you upgrade, your Backup Plus drive can upgrade right along with you.
- Seagate Backup Plus STDR1000200 - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.0
- Automatic backup
- Enclosure Colour
- Black
- 76 mm x 12.1 mm x 113.5 mm
- 140 g
- Localisation
- EMEA
- 2-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.0
- Automatic backup
- 76 mm
- 12.1 mm
- 113.5 mm
- 140 g
Expansion & Connectivity
- 1 x USB 3.0
- Software Included
- Seagate Dashboard
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.6 or later, Microsoft Windows XP (32/64 bits) SP3, Windows 8
- Cables Included
- 1 x USB cable - 45.7 cm
- Enclosure Colour
- Black
- Localisation
- EMEA
- Limited warranty - 2 years
