IronWolf Pro is designed for everything business NAS. Get used to tough, ready, and scalable 24×7 performance that can handle multidrive environments.
                Optimized for NAS with AgileArrayAgileArray enables dual-plane balancing and RAID optimization in multi-bay environments, with the most advanced power management possible.
                Rotational Vibration (RV) sensorsFirst in its class of drives to include RV sensors to maintain high performance in multi-drive NAS enclosures.
                Do more in multi-user environmentsIronWolf provides a workload rate of 300 TB/year. Multiple users can confidently upload and download data to the NAS server, knowing IronWolf can handle the workload, whether you are a creative professional or a small business.
- Seagate IronWolf Pro ST14000NE0008 - hard drive - 14 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 14 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- 24x7 continuous operation, Hot-Plug Support, advanced format 512e, rotation vibration sensor, AgileArray
- 101.85 mm x 146.99 mm x 26.11 mm
- 690 g
- 5-year warranty
- Bundled with
- 2 years Seagate Rescue Data Recovery
- Capacity
- 14 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- 101.85 mm
- 146.99 mm
- 26.11 mm
- 690 g
- Bundled with
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 250 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,200,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 5.3 Watt (idle) , 7.9 Watt (active) , 0.8 Watt (standby) , 0.8 Watt (sleep)
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 2 ms
- Vibration Tolerance (non-operating)
- 2.27 g @ 10-500 Hz
