Lightning-fast performance and titanic storage give your desktop or creative professional system the edge you need to be your very best.
Robust durability
Engineered to withstand the rigors of daily use, the Seagate Barracuda Pro offers a high non-recoverable error rate of 1 per 10^15 and a substantial load/unload cycle of 300,000, ensuring reliability and data integrity over time. -
Efficient performance
With an impressive internal data rate of 250 MBps and a large 12 TB capacity, this hard drive meets the demands of intensive data applications, while features like Native Command Queuing (NCQ) enhance performance efficiency. -
Eco-friendly design
The Seagate Barracuda Pro stands out with its Halogen Free construction and PowerChoice technology, which optimizes power consumption during active, idle, standby, and sleep modes, making it an environmentally conscious choice. -
Advanced connectivity
Featuring a Serial ATA-600 interface, the hard drive ensures high-speed data transfer rates up to 600 MBps, facilitating quick and seamless access to large files and applications. -
Data protection
Bundled with 2 years Seagate Rescue Data Recovery, this hard drive offers an additional layer of data protection, ensuring your valuable data is safeguarded against unforeseen events.
- Seagate Barracuda Pro ST12000DM0007 - hard drive - 12 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 12 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Halogen Free, PowerChoice, Hot-Plug Support, Worldwide Name (WWN), advanced format 512e, Perpendicular Recording, S.M.A.R.T.
- 101.85 mm x 146.99 mm x 26.11 mm
- 705 g
- 5-year warranty
- Bundled with
- 2 years Seagate Rescue Data Recovery
- Capacity
- 12 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- Bytes per Sector
- 4096
- 101.85 mm
- 146.99 mm
- 26.11 mm
- 705 g
- Bundled with
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 250 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,000,000 hours
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 7.8 Watt (active) , 4.83 Watt (idle) , 0.84 Watt (standby) , 0.8 Watt (sleep)
- Software Included
- Seagate SeaTools
- BSMI, ICES-003, EN55024, EN55022 Class B, RoHS, China RoHS, RCM, ASTM B845, FCC Part 15 J Class B, ACMA, Directive 2014/30/EU, ANSI C63.4-2014, AS/NZS CISPR 32
- Limited warranty - 5 years
- 0 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- 5 - 95% (non-condensing)
- Shock Tolerance (operating)
- 70 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 250 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.5 g @ 22-350 Hz
- Vibration Tolerance (non-operating)
- 2.27 g @ 2-500 Hz
