Lightning-fast performance and titanic storage up to 10TB give your desktop or creative professional system the edge you need to be your very best.
Robust durability
Designed to withstand the rigors of daily use, the Seagate Barracuda Pro hard drive offers a high tolerance to shock and vibration. With operating shock resistance up to 70 g and non-operating shock resistance up to 250 g, along with a vibration tolerance that ensures reliability in various environments, this hard drive is built for longevity. -
Efficient performance
The Seagate Barracuda Pro boasts an impressive internal data rate of 220 MBps and a large 10 TB capacity, making it an excellent choice for extensive storage needs. Coupled with a 7200 rpm spindle speed and advanced features like Native Command Queuing (NCQ) and PowerChoice technology, it delivers efficient performance and energy savings. -
Reliable operation
With an MTBF (Mean Time Between Failures) of 1,000,000 hours and support for S.M.A.R.T. standards, the Seagate Barracuda Pro is engineered for dependable operation. Its halogen-free construction and compliance with RoHS standards further underscore its reliability and commitment to environmental sustainability.
- Seagate Barracuda Pro ST10000DM0004 - hard drive - 10 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 10 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Halogen Free, PowerChoice, Hot-Plug Support, advanced format 512e, S.M.A.R.T.
- 101.85 mm x 146.99 mm x 26.11 mm
- 650 g
- 5-year warranty
- Capacity
- 10 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- Bytes per Sector
- 4096
- 101.85 mm
- 146.99 mm
- 26.11 mm
- 650 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 220 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,000,000 hours
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 6.8 Watt (active) , 4.5 Watt (idle) , 0.8 Watt (standby) , 0.8 Watt (sleep)
- RoHS
- Limited warranty - 5 years
- 0 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- 5 - 95% (non-condensing)
- Shock Tolerance (operating)
- 70 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 250 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.5 g @ 22-350 Hz
- Vibration Tolerance (non-operating)
- 2.27 g @ 2-500 Hz
