A CHOICE FOR YOU AND FOR THE ENVIRONMENT
Part of the Oceano Collection, the TWS eco-friendly wireless earphones were designed for those seeking a product with low environmental impact, for everyday use in managing calls and music. Even the base, which is used for holding and charging the earphones, is made of eco-sustainable materials.
ECO-SUSTAINABILITY
The wireless earphones and the base are 40% made of biodegradable materials, the Plastic Free package is made entirely of recycled paper and the ink used is eco-friendly. By choosing this product, you also contribute to the cause of MareVivo, the Italian association for the defence of the sea and its resources.
MUSIC AND CALLS
Thanks to TWS (True Wireless Stereo) technology, the earphones will automatically connect to each other without the use of cables. Using the multifunction keys, you can manage music and calls: you can answer or decline calls, recall the last number and play music or pause it. In addition, the earphones allow you to use the voice assistant function of your smartphone.
CASE AND CHARGING
Don't lose the earphones and charge them as needed. The 400 mAh charging base is used for holding and charging the earphones. Inside the package there is a USB - Micro USB cable for charging the base.
Eco-sustainability
The wireless earphones and the base are 40% made of biodegradable materials, the Plastic Free package is made entirely of recycled paper and the ink used is eco-friendly. -
Music and calls
- SBS Oceano - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Recommended Use
- Portable electronics
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 98 dB
- Controls
- Volume, answer/end
- Product Type
- True wireless earphones - Bluetooth - wireless
- Recommended Use
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- 20 - 20000 Hz
- Sensitivity
- 98 dB
Microphone
- Form Factor
- Built-in
Remote Control
- Controls
- Included Accessories
- Charging case (400 mAh)
- Cable Details
- Micro-USB charge cable
- Battery
- Headphone battery rechargeable
- Capacity
- 45 mAh
- Run Time (Up To)
- 3 hour(s)
- Standby Time
- 240 hours
- Recharge Time
- 1 hour(s)
