Keep your Apple Watch powered wherever you go with the Satechi USB-C Magnetic Charging Dock. Designed to fit all Apple Watch sizes, the Magnetic Charging Dock features an USB-C connection to recharge your Apple Watch when connected to any powered Type-C device. With its sleek yet ultra-portable design, the USB-C Magnetic Charging Dock helps keep your Apple Watch powered and on your wrist for when it matters most.
DESIGNED FOR APPLE WATCH
Features a built-in magnetic charging module to recharge your Apple Watch at full-speed, simply connect to any powered USB-C port.
PERFECT FOR ON-THE-GO
Its compact, portable design makes it easy to carry along with you – whether it’s in the office or on-the-go.
WORRY-FREE CHARGING
Enjoy worry-free charging with the Magnetic Charging Dock’s MFi certification for guaranteed compatibility with all Apple Watch models.
SLEEK ALUMINUM DESIGN
Features a modern space gray aluminum finish to complement your Apple Watch and MacBook accessories.
COMPATIBLE DEVICES
Apple Watch 6/SE/5/4/3/2/1
CONNECTOR TYPE
USB-C
DIMENSIONS & WEIGHT
1.73 x 2 x 0.45 inches, 1.1 oz
SPEED
Output: 5W
GUARANTEE
1 Year Manufacturer Warranty
Designed for Apple Watch
Features a built-in magnetic charging module to recharge your Apple Watch at full-speed, simply connect to any powered USB-C port. -
Perfect for on-the-go
Its compact, portable design makes it easy to carry along with you - whether it's in the office or on-the-go. -
Worry-free charging
Enjoy worry-free charging with the Magnetic Charging Dock's MFi certification for guaranteed compatibility with all Apple Watch models. -
Sleek aluminum design
- Satechi wireless charging pad - magnetic - 5 Watt
- Product Type
- Wireless charging pad
- Designed For
- Smart watch
- 4.4 cm x 5.1 cm x 1.1 cm
- 141 g
- Space grey
- Output Connector Type
- Magnetic
- Power Provided
- 5 Watt
- 1-year warranty
- Designed For
- Apple Watch
- Product Type
- Designed For
- Smart watch
- 4.4 cm
- 5.1 cm
- 1.1 cm
- 141 g
- Enclosure Colour
- Space grey
- Input Connectors
- 24 pin USB-C
- Output connectors
- Magnetic
- Power Provided
- 5 Watt
- Wireless Charging
- Material
- Aluminium
- MFI
- Limited warranty - 1 year
- Designed For
- Apple Watch
