Satechi TypeC to TypeC 100W Charging Cable
Quicklinx: GS53WS00 Mfr#: ST-TCC2MM
15 In Stock
£20.83 ex VAT
£24.99 inc VAT
The Satechi USB-C to USB-C Charging Cable is your high-speed charging solution for Type-C devices. Featuring reversible USB-C connectors on each side, the cable fully supports Power Delivery and data transfer between USB Type-C smartphones, tablets, and laptops.
Details
Powers your USB-C smartphones, tablets, & laptops
Supports PD charging up to 100W
Supports data transfer up to 480 Mbps
Longer 6.5 ft / 2 m cable design
COMPATIBLE DEVICES
2020/2019/2018/2017/2016 MacBook Pro, 2020/2018 MacBook Air, 2020/2018 iPad Pro, 2020 iPad Air, 2019/2017 iMac, iMac Pro, 2015/2016/2017 MacBook, Microsoft Surface Laptop 3/Surface Pro 7/Go, Google PixelBook Go, ChromeBook, Samsung Galaxy Tab Pro S, HP Spectre Convertible, Razer Blade, Huawei Matebook and more USB-C devices.
CONNECTOR TYPE
USB-C
DIMENSIONS & WEIGHT
6.5 ft / 2 meters, 3.8 oz
SPEED
Max power output: 100W
Data transfer up to 480 Mbps
  • High-speed charging solution
    A high-speed charging solution for Type-C devices.
  • Reversible USB-C
    Reversible USB-C connectors on each side.
  • Power Delivery and data transfer
    The cable fully supports Power Delivery and data transfer between USB Type-C smartphones, tablets, and laptops.
  • Charging up to 100W
    Supports PD charging up to 100W.
  • Transfer speed up to 480 Mbps
    Supports data transfer speeds up to 480 Mbps.
Satechi - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
USB Power Delivery (100W), braided, sync and charge
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
1-year warranty with 30 days money back guarantee
USB-C cable
Length
2 m
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0
