The Satechi Trio Wireless Charging Pad simplifies wireless charging with a convenient place for all your devices - so you'll never be without a charge. With faster-charging technology and intelligent safety features, the Charging Pad quickly powers a Qi-enabled smartphone, Apple Watch, and AirPods Pro all at the same time.
Simultaneously charges up to three devices – an Apple Watch (2.5W), AirPods with wireless charging case (5W), and a Qi-enabled iPhone (up to 7.5W).
Ideal for your on-the-go lifestyle, the charger is smartphone case friendly (up to 5mm thick) and supports Apple Watch in Nightstand mode.
Simply align your devices on the marked areas and LED lights will illuminate to indicate when each device has started to charge.
Equipped with foreign object detection (FOD) and over temperature protection
Tech Specs
COMPATIBLE DEVICES
iPhone 13 Pro Max/13 Pro/13, iPhone 12 Pro Max/12 Pro/12/12 mini, iPhone 11 Pro Max/11 Pro/11, XS Max/XS/XR/X/8 Plus/8, AirPods Pro/AirPods Gen 3/2, Apple Watch Series 7/6/SE/5/4/3/2/1, Samsung Galaxy S10+/S10/S9+/S9/S8+/S8 and other Qi-enabled smartphones. Supports only Qi-enabled devices. Includes 24W PD adapter. Magnetic charger will only magnetize with iPhone 13/12 models. If using with case, the magnetic feature will not function if case does not support MagSafe protocol.
Includes:
24W PD Adapter
USB-C Cable (40")
UK & EU Plug (AU Plug not included)
CONNECTOR TYPE
USB-C
DIMENSIONS & WEIGHT
4.53 x 8.66 x 0.51 inches, 13 oz
MODEL NO / UPC
ST-X3TWCPM / 879961008550
SPEED
iPhone: 7.5W
AirPods: Max 5W
Apple Watch: Max 2.5W
GUARANTEE
1 Year Manufacturer Warranty
A place for all your devices
Simultaneously charge up to three devices - an Apple Watch Series (up to 2.5W), AirPods with wireless charging case (up to 5W), and a Qi-enabled iPhone (up to 7.5W) or smartphone - all from one sleek, modern station. -
Designed for convenience
Ideal for your on-the-go lifestyle, the charger is smartphone case friendly (up to 5mm) and supports Apple Watch in Nightstand mode. -
Power effortlessly
Enjoy effortless charging - simply align your devices on the marked areas and LED lights will illuminate to indicate when each device has started to charge. -
Intelligent safety features
Equipped with foreign object detection (FOD) and over temperature protection, the Satechi Trio Wireless Charging Pad automatically detects and cuts off power when necessary.
- Satechi Trio Wireless Charging Pad wireless charging mat / power adapter - + AC power adapter - 24 Watt
- Product Type
- Wireless charging mat / power adapter + AC power adapter
- 22 cm x 11.5 cm x 1.3 cm
- 368 g
- Fast Charge Technology
- Power Delivery
- Wireless Charging
- Wireless Charging Standards
- Qi
- Power Provided
- 24 Watt
- Cables
- USB-C cable - 1 m
- 1-year warranty
- Product Type
- Designed For
- Mobile phone, smart watch, wireless earphones
- 22 cm
- 11.5 cm
- 1.3 cm
- 368 g
- Power Provided
- 24 Watt
- Wireless Charging
- Qi
- Power Delivery
- AC Power Adapter Included
- Included Accessories
- Power plug adapter (EU), power plug adapter (UK)
- Cables Included
- USB-C cable - 1 m
- Limited warranty - 1 year
