Complete your modern desk space, while working remotely or from home, with the Satechi Slim W3 wired backlit keyboard. Designed for Mac devices, the W3 Keyboard features an extended layout with a numeric pad and convenient shortcut keys optimized for Mac and iOS, all with an ultra-slim, modern design. Equipped with adjustable backlit keys and a wired USB Type-C connection, the keyboard allows you to work with ease wherever or whenever your creativity takes you.
Details
Designed for Mac & iOS devices
Hassle-free wired USB-C connection
Adjustable backlit keys
Modern aluminum design
Your all-in-one wired keyboard
Designed with Apple users in mind, the Satechi Slim W3 wired backlit keyboard includes all the features you need, like an extended keyboard layout with a numeric pad, wired USB Type-C connection, adjustable backlit keys, and MacOS function keys, all with a sleek aluminum finish. -
Illuminated keys
The Slim W3 wired keyboard includes backlit keys with three levels of brightness for the perfect amount of light in any setting, plus macOS function hotkeys to easily adjust brightness, volume, pause, play and more on your connected device. -
Hassle-free wired connection
Features built-in USB Type-C cable for a hassle-free, instant connection, with no extra setup required. Perfect for areas with poor wireless connectivity or when you just need a simple solution, the Slim W3 wired backlit keyboard will quickly become your go-to peripheral.
 - Satechi Slim W3 - keyboard - QWERTY - UK Input Device
 - Keyboard
- Backlit
- Interface
 - USB-C
- Connectivity Technology
 - Wired
- Localization and Layout
 - QWERTY UK
- Hot Keys Function
 - Application switching, search, mute, brightness, play/pause, previous track, next track, backlight control, volume -, volume +, FN key lock, eject
- Numeric Keypad
 - 42.3 cm x 11.4 cm x 0.99 cm
 - 440 g
 - 1-year warranty
 - Keyboard
- Backlit
- Interface
 - USB-C
- Hot Keys Function
 - QWERTY UK
- Detachable Cable
 - Numeric keypad
 - 42.3 cm
 - 11.4 cm
 - 0.99 cm
 - 440 g
- Included Accessories
 - USB cable
 - Limited warranty - 1 year
