The Slim W1 wired backlit keyboard is your modern, compact solution to upgrading your Mac setup. Featuring a full QWERTY layout, convenient function keys, and adjustable backlit keys - all with a hassle-free, wired connection. Equipped with a built-in USB-C cable, the Slim W1 wired backlit keyboard easily connects to your Type-C device for instant installation with no extra setup required.
Designed for Mac & iOS devices
Hassle-free wired USB-C connection
Adjustable illuminated keys
Sleek & ultra-compact design
COMPATIBLE DEVICES
Supports devices with a USB-C port including, 2020/2018 Mac Mini, 2020/2019/2017 iMac, 2020/2018 MacBook Air, 2020/2019/2018/2017/2016 MacBook Pro, 2020/2018 iPad Pro, 2020 iPad Air. Does not support devices with a standard USB-A port.
CONNECTOR TYPE
Wired USB-C
DIMENSIONS & WEIGHT
11.14 x 4.5 x 0.39 inches, 0.65 lbs
GUARANTEE
1 Year Manufacturer Warranty
Hassle-free wired connection
Features built-in USB-C cable for a hassle-free, instant connection - with no extra setup required. Perfect for areas with poor wireless connectivity or when you just need a simple solution, the W1 Wired Backlit Keyboard will quickly become your go-to peripheral. -
Illuminated keys
The Slim W1 Wired Keyboard includes backlit keys with three levels of brightness for the perfect amount of light in any setting, plus function hotkeys to easily adjust brightness, volume, pause, play, and more on your connected device. -
Modern & compact design
Its sleek aluminum finish and ultra-compact design make it a modern addition to any setup and can easily store away when not in use or when on-the-go.
- Satechi Slim W1 - keyboard - QWERTY - UK Input Device
- Keyboard
- Backlit
- Interface
- USB-C
- Connectivity Technology
- Wired
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Application switching, mute, brightness, play/pause, previous track, next track, backlight control, volume -, volume +, FN key lock, eject
- 28.3 cm x 11.4 cm x 0.99 cm
- 295 g
- 1-year warranty
- Keyboard
- Backlit
- Interface
- USB-C
- Hot Keys Function
- QWERTY UK
- 28.3 cm
- 11.4 cm
- 0.99 cm
- 295 g
- OS Required
- Apple MacOS, Apple iOS
- Limited warranty - 1 year ¦ Limited warranty - return - 30 days
