The Satechi Magnetic 2-in-1 Wireless Charging Stand combines the power of dual wireless charging with the convenience of hands-free magnetic attachment. Designed for iPhone 12/13 and AirPods Pro, the Stand features a built-in magnetic charger and a designated wireless charging pad to power both devices with ease.
Details
Built-in wireless charger for iPhone 12 & AirPods Pro
Features hands-free magnetic attachment for iPhone 12
Includes LED indicator light
Ultra-sleek & modern design
COMPATIBLE DEVICES
iPhone 13 Pro Max/13 Pro/13 Mini/13, iPhone 12 Pro Max/12 Pro/12 Mini/12 & AirPods Pro/AirPods with wireless charging case.
Magnetic Sticker (sold separately) required for iPhone 11 models & iPhone cases without MagSafe support.
CONNECTOR TYPE
USB-C Includes USB-C cable
DIMENSIONS & WEIGHT
5.47 x 3.54 x 0.51 inches, 0.64 lbs
SPEED
iPhone 13/12 - up to 7.5W AirPods Pro - 5W
GUARANTEE
1 Year Manufacturer Warranty
Two is better than one
Features a built-in magnetic wireless charger for iPhone 12 (7.5W) and a designated wireless charging pad for AirPods Pro (5W) to power both your devices with ease. -
Hands-free magnetic attachment
Equipped with a magnetic attachment for iPhone 12 models with MagSafe, the Stand allows for convenient, hands-free viewing with an adjustable mount to easily maneuver to the perfect angle. -
It's the little things
Includes a LED indicator light so you'll know when your devices are charging, a convenient USB-C port, and non-slip padding on the bottom to help prevent the stand from moving around.
- Satechi charging stand - magnetic - 7.5 Watt
- Product Type
- Charging stand
- Designed For
- Mobile phone, wireless earphones
- 9 cm x 9 cm x 13.9 cm
- 290 g
- Output Connector Type
- Magnetic
- Wireless Charging
- Wireless Charging Standards
- Qi
- Power Provided
- 7.5 Watt
- Cables
- USB-C cable
- 1-year warranty
- Designed For
- Apple AirPods (2nd generation, 3rd generation); AirPods Pro; iPhone 12, 12 mini, 12 Pro, 12 Pro Max
- Product Type
- Charging stand
- Designed For
- 9 cm
- 9 cm
- 13.9 cm
- 290 g
- Input Connectors
- 24 pin USB-C
- Output connectors
- Magnetic
- Power Provided
- 7.5 Watt
- Wireless Charging
- Qi
- Number Of Phones Wireless Charged Simultaneously
- 2
- LED indicator
- Material
- Aluminium
- Cables Included
- USB-C cable
- Limited warranty - 1 year
- Designed For
- Apple AirPods (2nd generation, 3rd generation) , Apple AirPods Pro , Apple iPhone 12, 12 mini, 12 Pro, 12 Pro Max
