Satechi Aluminum Wired Keyboard for Mac - Silver - UK
Quicklinx: GRMGWS00 Mfr#: ST-AMWKS-UK
Featuring enhanced scissor-switch keys and an extended keyboard layout, the Satechi Aluminum Wired Keyboard is a perfect solution for your Mac setup. Designed for Mac devices, the keyboard includes intuitive MacOS function hot keys for convenience at your fingertips. Highly responsive scissor-switch keys capture every keypress, ideal for everyday data entry or advanced accounting projects. Available in elegant color options to create the ideal keyboard for your modern desk space.
  • Extended keyboard layout
    Enjoy an extended keyboard layout with full numeric keypad, perfect for data entry, finance applications or accounting tasks. With responsive scissor switch keys, the keyboard captures every keypress for fast and precise typing.
  • Intuitive function keys
    With convenience at your fingertips, you will be able to pause/play, switch applications, adjust brightness and more, all with a press of a button. Since function keys were designed for MacOS, hot keys will not be compatible for all Windows computers.
  • Reliable wired connection
    With an included USB-A cable, you will enjoy a reliable wired connection for a surprisingly easy setup. Simply plug into one of your Mac's standard USB ports and follow on-screen instructions in "Keyboard Set Up Assistant" window to properly identify your keyboard.
Satechi Aluminum Wired Keyboard - keyboard - UK - silver Input Device
Keyboard
USB
Wired
Localization and Layout
Hot Keys Function
Application switching, search, mute, brightness, play/pause, previous track, next track, Mission Control, volume -, volume +, FN key lock, eject
Numeric Keypad
Silver
43.2 cm x 11.9 cm x 1.02 cm
476 g
1-year warranty
Keyboard
USB
Hot Keys Function
Keyboard Technology
Scissors
Numeric keypad
43.2 cm
11.9 cm
1.02 cm
476 g
Silver
Cable Length
1.4 m
Apple MacOS X 10.4 or later
Limited warranty - 1 year
