Building on its reputation for special editions and silent cooled graphics cards, the Ultimate Edition of the Sapphire HD 5670 boasts the full performance and features of the fan cooled models, but with a totally silent heatpipe cooler.
The Sapphire HD 5670 Ultimate has 400 Stream Processors and sports 1GB of the latest DDR5 memory. With clock speeds of 775MHz core and 1000MHz for the memory, it delivers the same performance as fan cooled models, but with a totally silent heatpipe cooler, making it the fastest silent cooled graphics card available today.
ATI Eyefinity
ATI Eyefinity technology maximizes your field of view across up to three displays, fully engaging your peripheral vision. For gamers this puts you right IN the game and for other applications it helps to increase productivity by maximizing your visual workspace so that you can see more windows simultaneously. ATI Eyefinity technology is also ideal for multimedia applications as it allows you to keep several 'palettes' or 'panels' open over a larger workspace whist you edit your images or videos. -
Advanced GDDR5 Memory technology
GDDR5 memory provides twice the bandwidth per pin of GDDR3 memory, delivering more speed and higher bandwidth. -
40nm Process technology
Cutting edge manufacturing process allows for efficient, high performance parts which use less power than their predecessors. -
ATI Stream technology
Accelerate the most demanding applications with ATI Stream technology and do more with your PC. ATI Stream technology allows you to use the teraflops of compute power locked up in your graphics processor on tasks other than traditional graphics such as video encoding, at which the graphics processor is many, many times faster than using the CPU alone. -
ATI CrossFireX Multi-GPU technology
Triple or quadruple with gaming power with ATI CrossFireX Multi-GPU technology. ATI CrossFireX technology supports up to four graphics cards to be used in a single system. -
PCI-Express 2.0
The PCI-Express 2.0 specification doubles data throughput from 2.5Gbps to 5Gbps allowing you to exploit the full performance potential of your graphics card. -
Dual-link DVI
Equipped with the most popular dual link DVI (Digital Visual Interface), this card is able to display ultra high resolutions of up to 2560 x 1600 at 60Hz. -
HDMI
Turn your PC into a home entertainment center with HDMI. Simply connect the graphics card to an LCD TV with an HDMI input and you will be able to enjoy watching HD videos with audio in the living room. -
DisplayPort
Enjoy the benefits of the display interface, DisplayPort. With the ultra high HD resolution of 2560 x 1600 the graphics card ensures that you are able to support the latest generation of LCD monitors. -
Microsoft DirectX 11
Get intense gaming performance and unrivaled image quality with stunning 3D visual effects, realistic lighting and lifelike imagery with Sapphire graphics cards supporting DirectX 11. Features in DirectX 11 such as Hardware Tesselation, HDR Texture Compression, Multi-threading support and DirectCompute bring lifelike gaming and an experience never possible on a PC before. -
Shader Model 5.0
Supports the latest Shader Model 5.0 feature set including VTF (Vertex Texture Fetch) which is a key feature used extensively in many of the games that ship today. Without support for this feature the game will fall back to a lesser shader path resulting in the loss of cool, lifelike effects made possible by Shader Model 5.0 -
Accelerated video transcoding
Massively parallel architecture and support for common shader transcoding instructions accelerates video encoding/transcoding way beyond what was possible with the CPU only. -
Dolby TrueHD and DTSHD Master Audio support
Support for copy protected, high bandwidth, 7.1 channel surround sound over HDMI. Get a fully immersive, high definition audio experience with the latest Blu-ray movies.
- Sapphire RADEON HD 5670 Ultimate - graphics card - Radeon HD 5670 - 1 GB
- Graphics card
- Bus Type
- PCI Express x16
- Graphics Engine
- ATI Radeon HD 5670
- Memory
- 1 GB GDDR5
- Core Clock
- 775 MHz
- Effective Memory Clock
- 1 GHz
- RAMDAC
- 400 MHz
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 3
- Interfaces Details
- VGA - with adapter , DVI-I , HDMI , DisplayPort
- API Supported
- DirectX 9.0, DirectX 11
- Package Type
- Lite retail
- Microsoft Certification
- Certified for Windows Vista
- Graphics card
- Bus Type
- PCI Express x16
- Graphics Engine
- Core Clock
- 775 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 2560 x 1600
- 3
- API Supported
- ATI Stream technology, Avivo Technology, ATI Eyefinity Technology, ATI CrossFireX Technology
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 1 GHz
- Required Power Supply
- 500 W
- System Requirements Details
- RAM 1 GB - HDD 200 MB
- Cables Included
- 1 x DVI-VGA adapter , 1 x HDMI-DVI adapter
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- RoHS
- Package Details
- Lite retail
