Sapphire Technology ATI Radeon 7750 HD 800MHz 1GB PCI-Express 3.0 HDMI
Quicklinx: 7YHMWS00 Mfr#: 11202-00-20G
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
  • Clock Spec: 800MHz/1125MHz
  • Memory Interface: 128-bit
  • Cooling Solution: 2 slot active
  • DVI to VGA Adaptor: Yes
  • Warranty: 2 Years Manufacturers Warranty
  • Dual-Link DVI
    It is equipped with the Dual Link DVI (Digital Visual Interface); this card is able to display ultra high resolutions of up to 2560 x 1600 at 60 Hz.
  • DisplayPort
    Enjoy the benefits of the latest generation display interface, DisplayPort. With the ultra high HD resolution, the graphics card ensures that you are able to support the latest generation of LCD monitors.
  • PCI Express 3.0
    PCI-Express 3.0 delivers double the bandwidth per lane of PCIe for fast GPU, maximizing the performance from your GPU.
  • AMD Eyefinity 2.0
    The AMD Eyefinity technology is here, featuring support for stereo 3D, universal bezel compensation and display configurations.
  • Enhanced multi-GPU capabilities
    Increase your gaming performance up to 2x with AMD CrossFire technology, the graphics card in slave modes will be switched off in idle to maximize the power saving.
  • OpenGL 4.2
    OpenGL 4.2 improves the GPU efficiency by improving the shader process operation and capturing GPU tessellated geometry. The process of modifying an arbitrary subset of compress texture is also simplified.
  • Microsoft DirectX11 support
    The tessellation performance on AMD Radeon HD7000 is fast, and direct compute performance is also fast to accelerate advanced post-processing, filtering, and anti-aliasing techniques. Direct X11 games has never looked this good.
  • Dolby TrueHD and DTSHD Master Audio support
    It supports for copy protected, high bandwidth, 7.1 channel surround sound over HDMI. Get a fully immersive, high definition audio experience with the latest Blu-ray movies.
  • AMD PowerTune technology
    AMD PowerTune is a breakthrough technology that sets a direction for maximum performance at TDP. It allows the GPU to be designed with high engine clock speeds which can be applied on the broad set of applications that have thermal headroom.
  • Display flexibility
    It offers an incredible choice of display connectivity options natively on the board, including dual-link DVI-I, DisplayPort and HDMI along with adapters to ensure compatibility with your legacy analog VGA monitor.
  • AMD PowerPlay with ZeroCore Power technology
    AMD PowerPlay is a power management technology in response to the GPU loading; AMD PowerPlay automatically manages the power consumption. AMD RADEON HD7000 series with AMD ZeroCore Power technology, the power consumption can be cut down, making the best use of power.
  • AMD HD Media accelerator
    AMD HD Media accelerator has been designed to help optimize and dramatically improve video playback on your computer by taking advantage of hardware video acceleration from your AMD Radeon GPU.
Graphics Processor Manufacturer
AMD
Graphics Processor
AMD Radeon HD 7750
PCI Express 3.0 x16
Memory Size
1 GB
Digital Output
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Core Clock
800 MHz
