Sapphire Technology ATI Radeon 6750 HD 700MHz 1GB PCI-Express HDMI
Quicklinx: 7HV7WS00 Mfr#: 11186-01-20G
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
Now, more people than ever can experience real innovation in DirectX 11 gaming with AMD Radeon HD 6750 Graphics. Expand your visual real estate across up to five displays and get lost in the action with AMD Eyefinity multi-display technology. Using AMD App Acceleration, speed up everyday applications and do more than ever with your PC. Loaded with advanced technologies, these GPUs have the power and premium features needed for fully immersive gameplay.
  • Advanced GDDR5 Memory Technology
  • AMD Eyefinity
  • 40nm Process Technology
  • AMD CrossFireX Multi-GPU Technology
  • 2 Year Manufacturer Warranty
  • Output: 1 x Dual-Link DVI, 1 x HDMI 1.4a, 1 x DisplayPort
  • GPU: 700 MHz Core Clock, 40 nm Chip, 720 x Stream Processors
  • Memory: 1024 MB Size, 128 -bit GDDR5, 4000 MHz Effective
  • Software: Driver CD
  • Accessory: DVI to VGA Adapter, 6 PIN to 4 PIN Power Cable
  • Warranty: 2 Years Manufacturers Warranty
  • Advanced GDDR5 memory technology
    GDDR5 memory provides twice the bandwidth per pin of GDDR3 memory, delivering more speed and higher bandwidth.
  • AMD Eyefinity
    AMD Eyefinity technology maximizes your field of view across up to three displays, fully engaging your peripheral vision. For gamers this puts you right IN the game and for other applications it helps to increase productivity by maximizing your visual workspace so that you can see more windows simultaneously.
  • 40 nm process technology
    Cutting edge manufacturing process allows for efficient, high performance parts which use less power than their predecessors.
  • AMD CrossFireX Multi-GPU technology
    Triple or quadruple gaming power with AMD CrossFireX Multi-GPU technology. AMD CrossFireX technology supports up to four graphics cards to be used in a single system.
  • PCI-Express 2.0
    The latest PCI-Express 2.0 specification doubles data throughput from 2.5 Gbps to 5 Gbps allowing you to exploit the full performance potential of your graphics card.
  • AMD HD3D technology
    Enjoy the most immersive experience possible with full support for high definition stereoscopic 3D, a technique that presents 2D images (movies, games, photos) in a format that creates the illusion of three-dimensional depth when using compatible 3D displays/glasses/software.
  • Dual-link DVI
    Equipped with the most popular dual link DVI (Digital Visual Interface), this card is able to display ultra high resolutions of up to 2560 x 1600 at 60 Hz.
  • DisplayPort
    Enjoy the benefits of the latest generation display interface, DisplayPort. With the ultra high HD resolution of 2560 x 1600 the graphics card ensures that you are able to support the latest generation of LCD monitors.
  • Microsoft DirectX 11
    Get intense gaming performance and unrivaled image quality with stunning 3D visual effects, realistic lighting and lifelike imagery with Sapphire graphics cards supporting DirectX11. New features in DirectX11 such as Hardware Tesselation, HDR Texture Compression, Multi-threading support and DirectCompute bring lifelike gaming and an experience never possible on a PC before.
  • OpenGL 4.1
    Supports the latest OpenGL API (Application Programming Interface) to accelerate performance of applications outside of DirectX, i.e. Adobe Autodesk 2D/3D graphic design.
  • Shader Model 5.0
    Supports the latest Shader Model 5.0 feature set including VTF (Vertex Texture Fetch) which is a key feature used extensively in many of the games that ship today. Without support for this feature the game will fall back to a lesser shader path resulting in the loss of cool, lifelike effects made possible by Shader Model 5.0
Sapphire RADEON HD 6750 - graphics card - Radeon HD 6750 - 1 GB
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6750
1 GB GDDR5
Core Clock
700 MHz
Effective Memory Clock
4 GHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
DVI-I , HDMI , DisplayPort
API Supported
DirectX 11, DirectCompute 11, OpenGL 4.1
Package Type
Lite retail
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6750
Core Clock
700 MHz
Max Resolution
API Supported
Video Transcoding (AVT), AMD Eyefinity Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD Advanced Parallel Processing technology, HDCP
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
4 GHz
Bus Width
128-bit
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows XP Media Center Edition 2005, Microsoft Windows Vista
Required Power Supply
450 W
Additional Requirements
CD-ROM, additional power connector
System Requirements Details
Windows XP/Vista/7 RAM 1 GB
Supported Windows 7 Features
Windows Media Center
Package Details
Lite retail
