The Sapphire HD 5450 graphic card offers the most features and functionality in their class with complete DirectX 11 support and the world's most advanced graphics, display features and technologies. The HD 5450 series is designed to give you stunning high definition entertainment from your PC, whether Blu-ray/HD DVD discs or other HD sources.
Accelerate
Perform tasks on a PC faster with ATI Stream technology, speed up demanding everyday applications and get more done in less time. -
Dominate
With DirectX 11 support you can play the latest HD games with unrivaled visual quality, astonishing realism and ultra-fast frame rates. -
Get unrivaled visual quality and intense gaming performance with support for Microsoft DirectX 11
Get striking 3D visual effects and dynamic interactivity with DirectX 11 support. DirectX 11 brings high levels of visual realism to gaming on the PC and you'll get top-notch performance for these titles with ATI Radeon HD 5400 series GPUs. -
Low power consumption, passive cooling, noise free
Sapphire HD5450 series consumes less 20W power. The passive cooling design is noise free.
- Sapphire RADEON HD 5450 - graphics card - Radeon HD 5450 - 512 MB
- Graphics card - low profile
- Bus Type
- PCI Express 2.1 x16
- Graphics Engine
- ATI Radeon HD 5450
- Memory
- 512 MB DDR3
- Core Clock
- 650 MHz
- Effective Memory Clock
- 1.6 GHz
- RAMDAC
- 400 MHz
- Max Resolution
- 2560 x 1600
- DVI-I (dual link) , HDMI , VGA
- API Supported
- DirectX 11
- Package Type
- Lite retail
- Microsoft Certification
- Certified for Windows Vista
- Bus Type
- Graphics Engine
- Core Clock
- 650 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11
- ATI Stream technology, Avivo Technology, ATI CrossFireX Technology
- Size
- 512 MB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.6 GHz
- Memory Allocation Technology
- HyperMemory
- Required Power Supply
- 500 W
- System Requirements Details
- RAM 1 GB - HDD 200 MB
- Included Accessories
- 2 low-profile brackets
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- WHQL, RoHS
- Package Details
- Lite retail
