Sapphire Technology ATI Radeon 3450 HD 512MB AGP HDMI
Quicklinx: 7MRBWS00 Mfr#: 11160-01-20R
  • High-Definition Multimedia Interface (HDMI)
The Sapphire HD 3450 AGP brings the features of the highly acclaimed HD 3000 series to the users of older PC systems with the AGP graphics bus. In addition to dramatically increased graphics performance, this means support for all the latest generation of games with DirectX 10.1 and the ability to smoothly play HD and Blu-Ray DVD's with the built-in hardware UVD decoder. It also allows users to accelerate tasks such as video transcoding (converting video formats to play on portable devices) and other new applications supporting AMD Stream technology.
  • 64-bit DDR2 memory interface
  • Microsoft DirectX 10.1 support
  • Shader Model 4.1
  • 32-bit floating point texture filtering
  • 2 Years Manufacturers Warranty
  • AGP based PC is required with one 4X/8X AGP slot available on the motherboard
  • 300 Watt or greater power supply is recommended with one 6 pin power connector
  • Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
  • 1GB of system memory recommended
  • Installation software requires CD-ROM drive
  • DVD playback requires DVD drive
  • Blu-ray playback requires Blu-ray drive and full 1080p display requires a 1080p-capable monitor
  • Warranty: 2 Years Manufacturers Warranty
Sapphire RADEON HD 3450 - graphics card - Radeon HD 3450 - 512 MB
Graphics card
Bus Type
AGP
Graphics Engine
ATI Radeon HD 3450
512 MB DDR2
Core Clock
600 MHz
Effective Memory Clock
400 MHz
RAMDAC
400 MHz
Memory Interface
64-bit
Max Monitors Supported
2
Interfaces Details
DVI-I , HDMI , VGA
API Supported
DirectX 10.1
Package Type
Lite retail
Microsoft Certification
Certified for Windows Vista
Graphics card
Bus Type
AGP
Graphics Engine
ATI Radeon HD 3450
Core Clock
600 MHz
RAMDAC
400 MHz
2
Interfaces Details
DVI-I , HDMI , VGA
API Supported
DirectX 10.1
Fanless heatsink
Size
512 MB
DDR2 SDRAM
Effective Clock Speed
400 MHz
Bus Width
64-bit
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
RoHS
Package Details
Lite retail
