SAPPHIRE Radeon™ RX 460 2G D5
For online gamers playing most popular titles such as Counter-Strike: Global Offensive, League of Legends or Overwatch SAPPHIRE Technology introduces the new inexpensive SAPPHIRE NITRO Radeon™ RX 460 graphics card. Featuring the latest power-efficient Polaris chip and making no compromises in cooling, the new budget king of the Radeon rebellion is an affordable upgrade to latest graphics technology.
Designed to perform great in massively popular online titles, the SAPPHIRE NITRO Radeon™ RX 460 promises minimum input lag and over 100 frames per second in Dota 2 or Rocket League in 1080p. Performance up to 30% better than R7 260X is the result of factory-overclocked 4th generation GCN core. The card features 896 stream processors with a boost clock up to 1210 MHz as well as 2 GB of GDDR5 video memory on 128-bit interface and clocked at 1750 MHz (7 Gbps effective speed).
Gamer optimized
Ideal for Online Gaming
With AMD Freesync and latency optimization , the Radeon RX 460 graphics card is the ideal solution for league of Legend, CS:GO and DOTA 2 at HD resolutions and beyond.
Prepared for Future Gamers
Powerful async shaders and new geometry capabilities enable unique support for DirectX 12 and Vulkan in the best version of Graphics Core Next yet.
Full HD HEVC Encode and Decode
Radeon GPUs based on the Polaris architecture are a dream for anyone that’s serious about streaming and recording their favorite games with virtually no performance impact. With a dedicated multimedia block 4K, H.265, 60 FPS encode and decode is now possible.
Cool and Efficient Perfromance
Cool Efficiency
The Polaris architecture precisely combines the latest FinFET 14 process technology and AMD’s advanced power, gating and clocking technologies for a superior cool and quite gaming experience.
Quiet Gaming
The latest SAPPHIRE Radeon RX 460 GPUs offer silent gaming features that dynamically optimizes sound volumes based on actual temperature and workloads.
Ready for the latest Displays
Radeon GPUs with the Polaris architecture support HDMI 2.0b and DisplayPort 1.3/1.4 for compatibility with and new generation of monitors that would make an gamer excited 1080p 240Hz, 1440p 240Hz, 4K 120Hz- even 1440p ultra-wide at 190Hz.
Game Changing Control
Radeon software
Radeon software drivers enable the ultimate in performance, features and stability to ensure an exceptionally smooth and fast out-of-box experience, and one that can get better with future updates.
Radeon WattMan (formerly AMD overdrive)
Push your hardware to limits. Radeon settings takes customization to a whole new level with per state control over clocks, voltages and temperature.
1st day Driver Support
Radeon software features planned up-to the minute game optimizations for performance enhancements and stability improvements.
Gamer optimized
Your ideal solution for your favorite games at HD resolutions and beyond! Step up to incredibly smooth and low-latency gaming at virtually any framerate thanks to AMD FreeSync technology. -
HD game streaming
Stream and record your favorite games with virtually no performance impact - thanks to Polaris architecture with Ultra HD HEVC Encode and Decode. With a dedicated multimedia block 4K, H.265, 60 FPS encode and decode is possible! -
Cool and efficient performance
Polaris architecture precisely combines the FinFET 14 process technology and AMD's advanced power, gating and clocking technologies for a whisper-quiet gaming experience. Enjoy gaming features that dynamically optimize sound volumes based on actual temperature and workloads.
- Sapphire RADEON RX 460 - graphics card - Radeon RX 460 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon RX 460
- Memory
- 2 GB GDDR5
- Core Clock
- 1210 MHz
- Stream Processors
- 896
- Memory Interface
- 128-bit
- Max Resolution
- 3840 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 / DisplayPort: 3840 x 2160 / HDMI: 3840 x 2160
- Max Monitors Supported
- 3
- Interfaces Details
- HDMI , DisplayPort , DVI-D
- API Supported
- DirectX 12, OpenGL 4.5, OpenCL 2.0
- 3.8 cm x 21.6 cm x 11.15 cm
- Package Type
- Lite retail
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon RX 460
- Core Clock
- 1210 MHz
- Stream Processors
- 896
- Process Technology
- 14 nm
- Max Resolution
- 3840 x 2160
- 3
- API Supported
- AMD Eyefinity Technology, AMD CrossFireX Technology, dual slot heatsink, Dolby True HD support, DTS-HD Master Audio support, Shader Model 5.0, Dual-X cooler, UEFI BIOS, AMD TrueAudio Technology, FreeSync Technology, Virtual Super Resolution (VSR), Frame Rate Target Control(FRTC), AMD XConnect Technology
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 128-bit
- OS Required
- Microsoft Windows 7 / 10
- Required Power Supply
- 400 W
- Additional Requirements
- CD-ROM
- 75 watt
- 3.8 cm
- 21.6 cm
- 11.15 cm
- Package Details
- Lite retail
