Sapphire Technology AMD Radeon R9 Fury X Graphics 4GB HBM PCIe3.0
Quicklinx: BFTXWS00 Mfr#: 21246-00-40G
  • AMD Radeon R9 Fury X
Like nothing you’ve seen before
The AMD Radeon™ R9 Fury X graphics card is the world’s first total solution GPU with AMD-pioneered High-Bandwidth Memory (HBM) on-chip delivering extreme 4K performance and unbelievably "real" VR experiences.
Don’t just upgrade. Revolutionize with the AMD Radeon™ R9 Fury X graphics card.
AMD High Bandwidth Memory
- High-Bandwidth Memory with more than 3x the bandwidth per watt over GDDR5 along with a 4096-bit memory interface - the highest AMD GPU memory bandwidth ever.
- Sleek industrial styling including GPU Tach activity indicator and LED illumination all in a compact 7.5-inch card that’s all about raw graphics power.
- Powerful performance, bleeding-edge technology, liquid-cooled, whisper-quiet and future-ready for extreme 4K and VR gaming.
Redefine reality with AMD LiquidVR™ technology.
- Liquid-smooth images with high frame rates for a definitive VR experience.
- Get comfortable with low-latency head tracking.
- Designed for plug-and-play headset compatibility.
Enjoy the View in 4K.
- Command the competition at 4K resolution and beyond, fueled by a 4096-bit high-bandwidth memory interface for extreme performance and power efficiency.
- Take advantage of full support for DirectX® 12, Vulkan™, OpenGL® 4.5 and Mantle.
- Experience the smoothest gameplay without frame-tearing or stuttering with an AMD Eyefinity 3x1, using 1440p FreeSync™-enabled monitors for a massive 6K gameplay "surround view" panorama.
  • Introducing AMD LiquidVR
    LiquidVR is an AMD initiative dedicated to making VR as comfortable and realistic as possible by creating and maintaining what's known as "presence" - a state of immersive awareness where situations, objects, or characters within the virtual world seem "real." Guided by close collaboration with key technology partners in the ecosystem, LiquidVR uses AMD's GPU software and hardware sub-systems to tackle the common issues and pitfalls of achieving presence, such as reducing motion-to-photon latency to less than 10 milliseconds. This is a crucial step in addressing the common discomforts, such as motion sickness, that may occur when you turn your head in a virtual world and it takes even a few milliseconds too long for a new perspective to be shown.
  • No stuttering, no tearing, just gaming
    AMD FreeSync technology allows a compatible graphics card and monitor to dynamically change frame rates for the optimum display quality without tearing or stuay.
  • DirectX 12
    DirectX 12 is a new, "console-like" graphics API from Microsoft that empowers game developers with more direct and obvious control of PC hardware. This direct or "explicit" control better exposes the hardware resources of AMD Radeon GPUs to yield higher hardware throughput and, ultimately, more performance for users. To put it simply: much more efficient hardware through smarter software! At the discretion of a game developer, this superior efficiency can be spent on higher framerates, lower latency (VR), lower power consumption, better image quality, or some calculated balance of all four. In any scenario, gamers stand to benefit greatly from choosing AMD hardware to run their favorite DirectX 12 game.
  • AMD Eyefinity technology
    Take your PC games to the next level of reality and immersion. Most modern games look great on three screens, and only AMD Radeon graphics offer you the ability to play across five screens for an eye-popping gaming experience. Other combinations and configurations with up to six screens work too. Create your dream display.
  • Harness the power of multiple GPUs
    AMD CrossFire technology is the ultimate multi-GPU performance gaming platform. Unlocking game-dominating power, AMD CrossFire harnesses the power of two or more discrete graphics cards working in parallel to dramatically improve gaming performance. AMD CrossFire technology ready graphics cards fit practically every budget. With the flexibility to combine two, three or four GPUs, AMD CrossFire technology is the perfect solution for those who demand extreme performance.
  • Your games now sound as good as they look
    The expectations of gamers have never been higher. Graphics quality and processing speed have advanced rapidly, and the games of today are light years ahead of those from just a few years ago. But advancements in game audio have been more sporadic and less widely adopted.
  • What it means for gamers
    By leveraging AMD TrueAudio technology, game developers now have the ability to recreate acoustic environments with incredible fidelity, and to bring them to every gamer. With AMD technology inside "next-generation" gaming platforms, including the PC, gamers across the entire industry will finally enjoy audio today's technology can offer.
Sapphire RADEON R9 FURY X - graphics card - Radeon R9 Fury X - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB HBM
Core Clock
1050 MHz
Stream Processors
4096
Effective Memory Clock
500 MHz
Memory Interface
4096-bit
Max Resolution
4096 x 2160
Max Resolution Details
DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
Max Monitors Supported
4
HDMI , 3 x DisplayPort , DVI - with adapter
API Supported
Mantle, DirectX 12, OpenGL 4.5, OpenCL 2.0, Vulkan
4 cm x 19.5 cm x 11 cm
Package Type
Retail
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1050 MHz
Stream Processors
4096
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
Dual Bios, AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, AMD PowerTune technology, Shader Model 5.0, Graphics Core Next (GCN), AMD ZeroCore Power technology, cutting-edge integrated display support, UEFI BIOS, AMD TrueAudio Technology, AMD Quad CrossFireX Technology, FreeSync Technology, AMD LiquidVR Technology, Virtual Super Resolution (VSR), AMD Water Cooling Technology, AMD XDMA CrossFire Technology, HDCP
Size
4 GB
HBM
Effective Clock Speed
500 MHz
Bus Width
4096-bit
Linux, Microsoft Windows 7 / 8 / 8.1 / 10
Min RAM Size
8 GB
Required Power Supply
750 W
Additional Requirements
CD-ROM, 2 x 8 pin PCI Express power connector
1 x HDMI cable - 1.8 m , 1 x DisplayPort-DVI cable
Software Included
Drivers & Utilities
4 cm
19.5 cm
11 cm
Package Type
Retail
