Sapphire Technology AMD Radeon 7730 HD 800MHz 2GB PCI-Express 3.0 HDMI
Quicklinx: 8Y9CWS00 Mfr#: 11211-02-20G
  • High-Definition Multimedia Interface (HDMI)
The Sapphire HD 7700 series is an extensive family of graphics cards targeting the enthusiast on a budget and mainstream users looking for increased graphics performance. It is based on the GPUs from AMD built in its 28 nm process and featuring the highly acclaimed GCN graphics processing architecture.
  • D-sub (VGA)
    The 15-pin VGA connector is common to most monitors and high definition television. You can connect your LCD or CRT monitor/TV with D-sub VGA connector.
  • Dual-Link DVI
    Equipped with the most popular Dual Link DVI (Digital Visual Interface), this card is able to display ultra high resolutions of up to 2560 x 1600 at 60 Hz.
  • Advanced GDDR5 memory technology
    GDDR5 memory provides twice the bandwidth per pin of GDDR3 memory, delivering more speed and higher bandwidth.
  • AMD Stream technology
    Accelerate the most demanding applications with AMD Stream technology and do more with your PC. AMD Stream technology allows you to use the teraflops of compute power locked up in your graphics processer on tasks other than traditional graphics such as video encoding, at which the graphics processor is many, many times faster than using the CPU alone.
  • AMD Avivo HD (DVD/HD-DVD/Blu-ray playback)
    Watch the hot Blu-ray movies or other HD content at full 1080p display resolution and beyond and enjoy a more feature rich experience with enhanced Unified Video Decoder (UVD).
  • AMD CrossFireX Multi-GPU technology
    Triple or Quadruple gaming power with AMD CrossFireX Multi-GPU technology. AMD CrossFireX technology supports up to four graphics cards to be used in a single system.
  • AMD HD3D technology
    Enjoy the most immersive experience possible with full support for High Definition Stereoscopic 3D, a technique that presents 2D images (movies, games, photos) in a format that creates the illusion of three-dimensional depth.
  • 28 nm GCN (Graphic Core Next) architecture
    The 28 nm GCN architecture with more efficient process technology puts more transistors in less space, enabling a dramatic increase in processing power. Crank the settings, devastate your enemies and bear witness to absurdly high frame rates with AMD Radeon HD7000 series graphics card-DirectX 11 has never looked this good. Maximum setting and crazy performance shouldn't be a compromise.
  • PCI Express 3.0
    PCI Express 3.0 delivers double the bandwidth per lane of PCIe Gen 2 for faster GPU, maximizing the performance from your GPU when paired with the latest platforms.
  • OpenGL 4.2
    OpenGL 4.2 improves the GPU efficiency by improving the shader process operation and capturing GPU tessellated geometry. The process of modifying an arbitrary subset of compress texture is also simplified. The memory management in handling shaders is more efficient as well.
  • Microsoft DirectX 11 support
    The tessellation performance on AMD Radeon HD7000 is up to 2x faster than the previous generation, and DirectCompute performance is also faster to accelerate advanced post-processing, filtering, and anti-aliasing techniques. DirectX 11 games has never looked this good.
  • Dolby TrueHD and DTSHD Master Audio support
    Support for copy protected, high bandwidth, 7.1 channel surround sound over HDMI. Get a fully immersive, high definition audio experience with the Blu-ray movies.
  • Anti-aliasing features
    Supports advanced AA (Anti-aliasing) features to maximize your enjoyment of high definition gaming.
  • Enhanced Unified Video Decoder 3 (UVD 3)
    Watch the hottest Blu-ray movies or other HD content at full 1080p display resolution. Enjoy a feature rich video experience with enhanced Unified Video Decoder 3 (UVD 3), offloading the bulk of the video decoding tasks from the CPU to the GPU allowing for a cooler, quieter and more balanced system.
  • AMD App Acceleration
    AMD App Acceleration is a set of technologies designed to improve video quality and enhance application performance. Full enablement of some features requires support for OpenCL, DirectCompute or DirectX Video Acceleration (DXVA).
  • AMD PowerPlay with ZeroCore Power technology
    AMD PowerPlay is a power management technology in response to the GPU loading, AMD PowerPlay automatically manages the power consumption. AMD RADEON HD7000 series with AMD ZeroCore Power technology, the power consumption can be as low as less than 3-watt when idle, making the best use of power.
  • AMD HD Media Accelerator
    AMD HD Media Accelerator has been designed to help optimize and dramatically improve video playback on your computer by taking advantage of hardware video acceleration from your AMD Radeon GPU. With full 3D stereoscopic decode you can enjoy it all in 3D. AMD HD Media Accelerator speeds up the decode of one 1080p and one 1080i HD video streams simultaneously by hardware, and the hardware encodes/transcoder processes your media content faster than ever!
  • Cutting-edge Quad HD display support (4K support)
    The display resolution on AMD Radeon HD7000 series is quadrupled to the resolution of 4K x 2K (4096 x 2160) from the outputs of DisplayPort 1.2 and HDMI.
Sapphire RADEON HD 7730 - graphics card - Radeon HD 7730 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7730
2 GB DDR3
Core Clock
800 MHz
Stream Processors
384
Effective Memory Clock
1.8 GHz
Memory Interface
128-bit
Max Monitors Supported
2
DVI-D (dual link) , HDMI , VGA
API Supported
DirectX 11, OpenGL 4.2
3.3 cm x 16.8 cm x 10.4 cm
Package Type
Lite retail
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7730
Core Clock
800 MHz
Stream Processors
384
Process Technology
28 nm
2
API Supported
AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Unified Video Decoder (UVD) 3, AMD Stream technology, AMD App Acceleration, Dolby True HD support, DTS-HD Master Audio support, Zero Core Power (ZCP), AMD HD Media Accelerator, Graphics Core Next (GCN), cutting-edge Quad HD display support, 24x Custom Filter Anti-Aliasing (CFAA)
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
128-bit
Microsoft Windows Vista / 7 / 8
Min RAM Size
4 GB
Required Power Supply
400 W
Additional Requirements
CD-ROM
Software Included
Drivers & Utilities, AMD Catalyst Control Center
3.3 cm
16.8 cm
10.4 cm
Package Details
Lite retail
