With Sanyo's advanced waterproofing technology, the Sanyo Xacti WH1 can be used without thinking twice in the rain; for water sports such as surfing or snorkeling, or for winter sports such as skiing or snowboarding. This Xacti camera keeps up with active lifestyles,
The Sanyo Xacti VPC-WH1 has earned the highest possible IEC 60529 waterproof rating - IPX8 - allowing high definition 1280 x 720, 30 fps footage to be captured without worrying about the effects of water or snow.
- Sanyo Xacti VPC-WH1 - camcorder - storage: flash card
- Product Type
- Camcorder - 720p
- Media Type
- Flash card
- Memory Card Slot
- SD card
- Sensor Resolution
- 1.1 MP
- Effective Sensor Resolution
- Photo: 1.1 MP
- Lens System
- Zoom lens - 30x zoom - 2.5 - 75 mm - f/1.8-4.3
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 50 cm
- Digital Zoom
- 50x
- Image Stabiliser
- Electronic
- Camera Flash
- Built-in flash
- Display
- LCD display - 2.5"
- Supported Battery
- Sanyo DB-L50 Li-ion rechargeable battery - 1900 mAh (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- 5.9 cm x 11.2 cm x 6.3 cm
- Product Type
- Camcorder - 720p
- Camcorder Type
- Consumer
- Camcorder Sensor Resolution
- 1.1 MP
- Sensor Qty
- 1 CMOS
- Effective Photo Resolution
- 1.1 MP
- Camcorder Interpolated Photo Resolution
- 2.0 MP
- Widescreen Video Capture
- Camcorder Media Type
- Flash card
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/6"
- ISO (Max)
- 3200
- Optical Zoom
- 30x
- Digital Zoom
- 50x
- Image Stabiliser
- Electronic
- Face Detection
- Print Standard
- Direct print, DPOF support
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 9
- Digital Video Format
- MPEG-4, H.264
- Image Recording Format
- JPEG
- Interface
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 50, ISO 1600, ISO 3200, ISO auto (50-200)
- Exposure Metering
- Multi-segment, centre-weighted, spot
- Exposure Modes
- Programme, automatic
- Shooting Programs
- Landscape, portrait mode, beach/snow, night portrait, fireworks, Underwater, sports mode, lamp
- Special Effects
- Black & White, Sepia, cosmetic
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Incandescent, fluorescent, cloudy, sunlight
- Max Shutter Speed
- 1/10000 sec
- Min Shutter Speed
- 2 sec
- Exposure Compensation
- ±1.8 EV range, in 1/3 EV steps
Lens System
- Focal Length Equivalent to 35mm Camera
- 43 - 1290mm
- Focus Adjustment
- Automatic, manual
- 50 cm
- Macro Focus Range
- 1-100cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 7 groups / 10 elements
- Aspherical lens, built-in neutral density filter
Camera Flash
- Camera Flash
- Built-in flash
- Guide Number (m / ISO 100)
- 3.8
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode
- Effective Flash Range
- 0.5 m - 4.2 m
Additional Features
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Audio recording, built-in speaker, digital noise reduction, in-camera red-eye fix
Display
- 2.5" LCD display
- Display Format
- 150,000 pixels
- Display Form Factor
- Rotating
- Display Features
- Contrast control, display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Microphone Features
- Wind noise reduction
- Connector Type
- HDMI , Composite video/audio output , USB
Software
- Software
- Drivers & Utilities
- Included Accessories
- Power adapter, USB cable, audio / video cable
- Underwater Use
- Underwater Depth
- Up to 1.5 m
- Battery Type
- Sanyo DB-L50 Lithium Ion
- Details
Memory / Storage
- RAM Installed
- 43 MB
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDHC Memory Card
- Image Storage
- JPEG 1600 x 1200 , JPEG 1184 x 888 , JPEG 1280 x 720 , JPEG 640 x 480
- Video Capture
- MPEG-4 - 1280 x 720 - 30 fps ¦ MPEG-4 - 640 x 480 - 60 fps ¦ MPEG-4 - 640 x 480 - 30 fps
- 5.9 cm
- 11.2 cm
- 6.3 cm
- 0 °C
- 40 °C
- 30 - 90%
