Sanyo VPC-WH1 Waterproof Digital HD 720p Camcorder White
Quicklinx: 659FWS00 Mfr#: VPC-WH1EW
  • SDHC Memory Card
With Sanyo's advanced waterproofing technology, the Sanyo Xacti WH1 can be used without thinking twice in the rain; for water sports such as surfing or snorkeling, or for winter sports such as skiing or snowboarding. This Xacti camera keeps up with active lifestyles,
The Sanyo Xacti VPC-WH1 has earned the highest possible IEC 60529 waterproof rating - IPX8 - allowing high definition 1280 x 720, 30 fps footage to be captured without worrying about the effects of water or snow.
Sanyo Xacti VPC-WH1 - camcorder - storage: flash card
Camcorder - 720p
Media Type
Flash card
Memory Card Slot
SD card
Sensor Resolution
1.1 MP
Effective Sensor Resolution
Photo: 1.1 MP
Lens System
Zoom lens - 30x zoom - 2.5 - 75 mm - f/1.8-4.3
Focus Adjustment
Automatic, manual
Min Focus Distance
50 cm
Digital Zoom
50x
Image Stabiliser
Electronic
Camera Flash
Built-in flash
Display
LCD display - 2.5"
Supported Battery
Sanyo DB-L50 Li-ion rechargeable battery - 1900 mAh (included)
Composite video/audio, HDMI, USB 2.0
5.9 cm x 11.2 cm x 6.3 cm
Camcorder - 720p
Camcorder Type
Consumer
Camcorder Sensor Resolution
1.1 MP
Sensor Qty
1 CMOS
Effective Photo Resolution
1.1 MP
Camcorder Interpolated Photo Resolution
2.0 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
CMOS
Optical Sensor Size
1/6"
ISO (Max)
3200
Optical Zoom
30x
Digital Zoom
50x
Image Stabiliser
Electronic
Face Detection
Print Standard
Direct print, DPOF support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
9
Digital Video Format
MPEG-4, H.264
Image Recording Format
JPEG
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 50, ISO 1600, ISO 3200, ISO auto (50-200)
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, portrait mode, beach/snow, night portrait, fireworks, Underwater, sports mode, lamp
Special Effects
Black & White, Sepia, cosmetic
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, sunlight
Max Shutter Speed
1/10000 sec
Min Shutter Speed
2 sec
Exposure Compensation
±1.8 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
43 - 1290mm
Focus Adjustment
Automatic, manual
Min Focus Distance
50 cm
Macro Focus Range
1-100cm
Zoom Adjustment
Motorised drive
Lens Construction
7 groups / 10 elements
Aspherical lens, built-in neutral density filter
Camera Flash
Camera Flash
Built-in flash
Guide Number (m / ISO 100)
3.8
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode
Effective Flash Range
0.5 m - 4.2 m
Additional Features
Self-Timer Delay
10 sec, 2sec
Additional Features
Audio recording, built-in speaker, digital noise reduction, in-camera red-eye fix
Display
2.5" LCD display
Display Format
150,000 pixels
Display Form Factor
Rotating
Display Features
Contrast control, display brightness control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction
Connector Type
HDMI , Composite video/audio output , USB
Software
Software
Drivers & Utilities
Power adapter, USB cable, audio / video cable
Underwater Use
Underwater Depth
Up to 1.5 m
Battery Type
Sanyo DB-L50 Lithium Ion
Details
Memory / Storage
RAM Installed
43 MB
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDHC Memory Card
Image Storage
JPEG 1600 x 1200 , JPEG 1184 x 888 , JPEG 1280 x 720 , JPEG 640 x 480
Video Capture
MPEG-4 - 1280 x 720 - 30 fps , MPEG-4 - 640 x 480 - 60 fps , MPEG-4 - 640 x 480 - 30 fps
5.9 cm
11.2 cm
6.3 cm
30 - 90%
