Sanyo Replacement lamp for PLC-HP7000
Quicklinx: 9VYJWS00 Mfr#: 610-357-0464
£387.45 ex VAT
£464.94 inc VAT
The projector PLC-HP7000L supports Full HD resolution without any image compression. Advanced optical QuaDrive engine achieves the high brightness of 7000 lumens with just one high-output lamp in the compact black long-lasting body.
SANYO's Unique QuaDrive engine evolves into a new generation standard. The color control device in the QuaDrive optical engine allows the PLC-HP7000L to automatically control the amount of yellow light in the image, producing higher luminosity with improved color accuracy and clarity.
  • 1080P, high brightness of 7,000 lumens
  • QuaDrive engine allows rich color and high contrast
  • Super high contrast design
    This advanced optical system and Durable Inorganic Optical System (D.I.O.S.) achieve high contrast to project high-quality images with rich black reproduction, maximizing the quality of the video signals.
  • Active maintenance filter (amf) for easy maintenance
    Minimal maintenance and repair was essential for the PLC-HP7000L, so it was outfitted with SANYO's exclusive Active Maintenance Filter (AMF). AMF is a single filter cartridge that contains the equivalent of 10 filters, reducing the burden of maintenance. It also has an airflow sensor to detect when the airflow is obstructed by dust, the filter automatically advances.
  • Network connectivity
    A built-in LAN allows for simple control and management of projectors via a CAT5 network connection. The administrator is able to centrally control all built-in LAN projectors in the network. Besides built-in network, optional PJ-Net Camera (POA-PN03C) and PJ Master Software are available.
  • Crestron RoomView/AMX device discovery compatibility
    PLC-HP7000L supports Crestron RoomView and AMX Device Discovery which facilitates the remote management and centralized control.
  • Various features for versatile installation
    When blending 2 or more projectors, the projector has versatile functions. 'Edge Blending' function allows lifelike boundary-less images with multi-image displays. And built-in 'Color Matching' function corrects variations in color reproduction for multiple projector usage.
  • Built in mechanical shutter
    A special mechanical shutter has been included behind the lens, open/close controllable with the remote control, which darken the screen in a moment.
Sanyo projector lamp
Projector lamp
PLC-HP7000L
Projector lamp
Sanyo PLC-HP7000L
Type: Projector lamp
Brand: Sanyo
