The SANUS VuePoint F58c is an unparalleled wall mount solution for most 47" - 80" flat panel TVs up to 130 lbs. This mount features an exclusive tilting technology for effortless adjustment of viewing angles, helping to reduce glare with up to 15ยบ of tilt without the use of tools. Its low-profile design places the TV just 2" from the wall for a clean, flush appearance. Laterally adjustable TV brackets allow the mount to shift left and right on the wall plate for perfect placement, even with off-center wall studs. A quick latching mechanism holds the TV securely on the wall, and solid construction provides strength and durability.
- Sanus VuePoint mounting kit - for flat panel
- Product Type
- Mounting kit
- Mounting Components
- Tilt wall mount
- Tilt
- 15°
- Recommended Use
- Flat panel
- Recommended Display Size
- 47"-80"
- VESA Mounting Interface
- Up to 800 x 600 mm
- Max Load Weight
- 59 kg
AV Furniture
- Mounting kit
- Tilt wall mount
- Recommended Use
- Flat panel
- 47"-80"
- Tilt
- 15°
- Max Load Weight
- 59 kg
