Sanus VuePoint Single Accessory Shelf TV Wall Bracket
Quicklinx: FW2LWS00 Mfr#: FPA400-B2
£33.33 ex VAT
£39.99 inc VAT
Sanus VuePoint FPA400 is a single-column AV component system that mounts directly under wall-mounted TVs for a sleek, streamlined look. Its center column features an integrated channel for easy power cable and signal wire routing. Thick tempered-glass shelf support up to 15 lbs and can be vertically adjusted to accommodate any AV component arrangement. Combine more than one FPA400 for a multiple shelving unit.
Sanus VuePoint FPA400 mounting component - for AV System - black
Mounting component
Mounting Components
Shelf
Recommended Use
AV System
AV Furniture
Mounting component
Mounting Components
Shelf
Recommended Use
AV System
Resources
The following resources are available for the Sanus VuePoint Single Accessory Shelf TV Wall Bracket
Type: Mounting component
Brand: Sanus
