Sanus VuePoint Low-Profile Wall Mount - 47"-80" TVs
Quicklinx: FW2JWS00 Mfr#: F55C-B2
Type: Mounting kit
15 In Stock
£33.33 ex VAT
£39.99 inc VAT
The Sanus VuePoint F55c is a superior wall mount solution for most 47" - 80" flat-panel TVs up to 130 lbs. Its ultra low-profile design sits just 1" from the wall to maximize the sleek, thin look of the TV. Brackets easily shift left and right on the wall plate to allow perfect TV placement, even with off-center wall studs. A quick latching mechanism holds the TV securely on the wall for added safety. The F55b is pre-assembled and is easily installed in minutes. Solid construction is strong and durable.
Sanus VuePoint F55c mounting kit - for flat panel - black
Mounting kit
Mounting Components
Wall mount
69.34 cm x 2.54 cm x 48.51 cm
Recommended Use
Flat panel
Recommended Display Size
47"-80"
VESA Mounting Interface
From 75 x 75 mm, up to 675 x 405 mm
Max Load Weight
59 kg
5-year warranty
69.34 cm
2.54 cm
48.51 cm
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
47"-80"
Max Load Weight
59 kg
Limited warranty - 5 years
Resources
The following resources are available for the Sanus VuePoint Low-Profile Wall Mount - 47"-80" TVs
Type: Mounting kit
Brand: Sanus
