The Sanus VuePoint F180c is a versatile full-motion wall mount solution for most 47" - 70" flat-panel TVs. Its full range of movement allows smooth extend, tilt, swivel and roll motions up to 15" from the wall without the use of tools. The F180c tilts +11º/-12º with the touch of a finger, making it easy to reduce glare. Cable management tie clips conceal and organize cables the length of the mount for a seamless appearance. Lateral shift ensure perfect TV placement, even with off-center wall studs.
- Sanus VuePoint mounting kit - for flat panel
- Product Type
- Mounting kit
- Mounting Components
- Full motion wall mount
- Tilt
- 23°
- Pan
- 120°
- Recommended Use
- Flat panel
- Recommended Display Size
- 47"-70"
- VESA Mounting Interface
- Up to 600 x 400 mm
- Max Load Weight
- 45 kg
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Cable Management
- Integrated cable management
- 47"-70"
- Tilt
- 23°
- Pan
- 120°
- Max Load Weight
- 45 kg
