Get all the accessories you need for your new TV with this Secura wall bracket starter kit, designed for TVs between 40 and 70 inches in size. You’ll be able to easily connect your console and Blu-ray player using the two meter long HDMI cable provided. This kit also includes an extension lead with four sockets – ideal for a mounted set up that has multiple mains powered devices. You can keep all your wires tidy too, using a set of five reusable cable ties. The VESA mount included is designed for TVs that have a VESA mount size between 100 x 100mm and 600 x 400mm.
 - Sanus QLTK1-B4 bracket - for LCD TV
- Product Type
 - Bracket - wall-mountable
- Tilt
 - -10° to 0°
- Recommended Use
 - LCD TV
- Recommended Display Size
 - 32"-65"
- Max Load Weight
 - 45 kg
- Package Content
 - HDMI cable, surge protector, 5 x cable ties
- Package Content
AV Furniture
 - Bracket
- Recommended Use
 - LCD TV
- Placing / Mounting
 - Wall-mountable
 - 32"-65"
- Tilt
 - -10° to 0°
- Max Load Weight
 - 45 kg
