Sanus VuePoint Bundle Kit -Tilting Mount/HDMI/Surge Protector/Ties
Quicklinx: FW2QWS00 Mfr#: QLTK1-B4
Type: Bracket
22 In Stock
£33.33 ex VAT
£39.99 inc VAT
Get all the accessories you need for your new TV with this Secura wall bracket starter kit, designed for TVs between 40 and 70 inches in size. You’ll be able to easily connect your console and Blu-ray player using the two meter long HDMI cable provided. This kit also includes an extension lead with four sockets – ideal for a mounted set up that has multiple mains powered devices. You can keep all your wires tidy too, using a set of five reusable cable ties. The VESA mount included is designed for TVs that have a VESA mount size between 100 x 100mm and 600 x 400mm.
Sanus QLTK1-B4 bracket - for LCD TV
Bracket - wall-mountable
Tilt
-10° to 0°
Recommended Use
LCD TV
Recommended Display Size
32"-65"
Max Load Weight
45 kg
Package Content
HDMI cable, surge protector, 5 x cable ties
Package Content
AV Furniture
Bracket
Recommended Use
LCD TV
Placing / Mounting
Wall-mountable
32"-65"
Tilt
-10° to 0°
Max Load Weight
45 kg
Type: Bracket
Brand: Sanus
