Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
Sanus Universal Speaker Wall Mount White - works with Sonos
Quicklinx: FY7DWS00 Mfr#: WSWM21-W2
Type: Bracket
£24.99 ex VAT
£29.98 inc VAT
Enjoy optimal audio quality from anywhere in the room with the SANUS WSWM adjustable wall mount, designed especially for the Sonos ONE, PLAY:1 and PLAY:3 as well as other wireless speakers weighing up to 10 lbs. Installing to drywall, wood studs or concrete in only 15 minutes and boasting effortless tilt and swivel capability, the placement flexibility of the WSWM makes it versatile enough for any system setup and for voice integration technology like that of Sonos ONE. Wary of mounting your Sonos ONE to the wall? Rest assured that your speaker will stay safe and in-place thanks to exclusive InvisiGrip technology: Two ultra-thin yet ultra-strong, virtually invisible wires wrapping around the top and bottom of your speaker to keep it snugly in place.
  • Tool-free tilt and swivel
    Enjoy perfect listening from anywhere in the room with 132 degrees of speaker swivel. Plus, its 30-degree tilt provides excellent sound whether you're listening sitting down or standing up. Sleek, subtle mounting solution facilitates immersive audio in your kitchen, home theater or any room you choose.
  • InvisiGrip technology
    Rest assured that your speaker will stay safe and in-place thanks to exclusive InvisiGrip technology: Two ultra-thin yet ultra-strong, virtually invisible wires wrap around the top and bottom of your speaker to keep it snugly in place.
  • Versatile use
    The placement flexibility of the WSWM makes it versatile enough for any system setup and voice integration technology.
  • 15-minute assembly
    Easy, 3-step installation gets your speaker up on the wall and ready to rock in 15 minutes or less.
Sanus WSWM21 bracket - for speaker(s) - white
Bracket - wall-mountable
5.06 cm x 7.03 cm x 9.72 cm
Tilt
30°
Pan
132°
Adjustments
Tilt, swivel
572 g
Recommended Use
Speaker(s)
Max Load Weight
4.54 kg
White
5-year warranty
Sonos One, PLAY:1, PLAY:3
5.06 cm
7.03 cm
9.72 cm
572 g
White
AV Furniture
Bracket
Recommended Use
Speaker(s)
Placing / Mounting
Wall-mountable
Tilt
30°
Pan
132°
Adjustments
Tilt, swivel
Max Load Weight
4.54 kg
Limited warranty - 5 years
Type: Bracket
Brand: Sanus
