Sanus SimplySafe Fixed Position Wall Mount - 47"-80" TVs
Quicklinx: D8WZWS00 Mfr#: VLL61-B2
Type: Mounting kit
£33.33 ex VAT
£39.99 inc VAT
Low-profile fixed wall mount solution for most 47–80" flat-panel TVs. Design places the TV just over 1" from the wall. Angled slots and integrated level make levelling and installation quick and easy. Lateral shift allows TV to slide left and right for perfect TV placement, even with off-center studs. Safety latch secures the TV to the wall for added safety.
For 47-80" Screens
Maximum Supporting Weight 61kg
With Locking Mechanism
Aluminium & Steel Construction
For Internal Use
Close-to-Wall Positioning
Sanus SimplySafe VLL61-B2 mounting kit - for TV
Mounting kit
Mounting Components
Fixed wall mount
Recommended Use
TV
Recommended Display Size
47"-80"
AV Furniture
Mounting kit
Mounting Components
Fixed wall mount
Recommended Use
TV
47"-80"
Type: Mounting kit
Brand: Sanus
