Sanus SimplySafe Fixed Position TV Wall Mount - 22"-50" TVs
Quicklinx: FW2PWS00 Mfr#: VML41-B2
Type: Mounting kit
11 In Stock
£24.99 ex VAT
£29.98 inc VAT
The Sanus SimplySafe mount is a low-profile wall mount solution for most 22" - 50" flat-panel TVs up to 80 lbs. Its low-profile design places the TV just 1.1" from the wall, so it hangs like a work of art. Angled slots and an integrated level make leveling and installation quick and easy. A safety latch secures your TV to the wall for added safety.
Sanus SimplySafe VML41 mounting kit - for TV - black
Mounting kit
Mounting Components
Fixed wall mount
45.09 cm x 7.04 cm x 2.84 cm
Tilt
Adjustments
Tilt
1.77 kg
Recommended Use
TV
Recommended Display Size
22"-50"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 400 x 300 mm, 400 x 100 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 300 x 100 mm, 200 x 100 mm, 300 x 300 mm, 100 x 200 mm, 200 x 300 mm, 300 x 400 mm
Max Load Weight
36.29 kg
10 years warranty
45.09 cm
7.04 cm
2.84 cm
1.77 kg
AV Furniture
Mounting kit
Mounting Components
Fixed wall mount
Recommended Use
TV
22"-50"
Tilt
Adjustments
Tilt
Max Load Weight
36.29 kg
Limited warranty - 10 years
Type: Mounting kit
Brand: Sanus
