Sanus Echo Show 8 Stand - White
Quicklinx: FZYBWS00 Mfr#: WSECS1-W2
Type: Stand
Colours:
£20.83 ex VAT
£24.99 inc VAT
The WSECS1 specially designed to work with the Amazon Echo Show 8. Offering up to 50-degrees of device up-tilt and 28-degrees of down-tilt, this stand is perfect for video calling. Full, 360-degree swivel capability lets you point your Amazon Echo Show 8 in any direction you'd like. Easy-Glide Magnet Technology provides smooth device tilt and swiveling. Durable design and sturdy rubber-ring footing prevent slipping and sliding.
Product Features
Designed for Amazon Echo Show 8
Stable magnetic design prevents unwanted movement and drifting.
Swivels up to 360° for the perfect view wherever you need it.
Durable design and sturdy rubber-ring footing prevents slipping and sliding.
No assembly required. Connect to your Echo Show 8 and it’s ready for use!
Tilt for easy viewing and to eliminate glare.
50° of up tilt and 28° of down tilt for optimal positioning
Sanus stand - for smart display - white
Stand - desktop
Adjustments
Tilt, swivel
Recommended Use
Smart display
White
Amazon Echo Show 8
White
AV Furniture
Stand
Recommended Use
Smart display
Placing / Mounting
Desktop
Adjustments
Tilt, swivel
Amazon Echo Show 8
Type: Stand
Brand: Sanus
