High Performance and High Reliability Meet High Style
Built with SanDisk’s sixth-generation TLC flash, the X400 SSD offers quick responsiveness, high reliability and low power for a seamless experience for thin and ultramobile notebooks. It’s the ideal storage solution for heavy workloads such as photo and video editing, multitasking or office productivity.
Thin Is In
With a 1.5mm single-sided form factor (M.2 2280 module), the X400 SSD is the first single-sided 1TB SSD in the industry, giving it the performance and capacities ideal for ultrathin designs. The X400 SSD is also available in 2.5" 7mm-height to be a true drop in replacement for mechanical HDDs.
nCache TM 2.0 and DataGuardTM: Advanced Technologies for A Better Experience
SanDisk technologies combine nCache 2.0, DataGuard and LDPC error correction into the X400 SSD for a superior experience and endurance levels up to 320 TBW (terabytes written), our highest ever for a client drive. SanDisk nCache 2.0 is a set of advanced algorithms that analyze workloads to improve fast burst performance and sustained sequential write speeds while minimizing energy consumption and controller overhead. The X400 SSD is backed by a 5-year warranty.
Designed With Security in Mind
The X400 SSD includes self-encrypting drive (SED) capabilities to quickly and easily protect sensitive documents from theft or disclosure. We also support TCG Opal 2.0 for interoperability with a wide spectrum of security software platform.
High performance and reliability meet high style
Built with SanDisk's TLC flash, the X400 SSD offers quick responsiveness, high reliability and low power for a seamless experience for thin and ultramobile notebooks. It's the ideal storage solution for heavy workloads such as photo and video editing, multitasking or office productivity. -
Advanced technologies for a better experience
SanDisk technologies combine nCache 2.0, DataGuard and LDPC error correction into the X400 SSD for a superior experience and high endurance levels. SanDisk nCache 2.0 is a set of advanced algorithms that analyze workloads to improve fast burst performance and sustained sequential write speeds while minimizing energy consumption and controller overhead. -
Designed with security in mind
The X400 SSD features self-encrypting drive (SED) capabilities to quickly and easily protect sensitive documents from theft or disclosure. It also supports TCG Opal 2.0 for interoperability with a wide spectrum of security software platform.
- SanDisk X400 - SSD - 1 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 1 TB
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Device Initiated Power Management (DIPM), DEVSLP SATA low power mode, DataGuard Technology, nCache 2.0 technology, LDPC error correction
- 69.85 mm x 100.5 mm x 7 mm
- 59.7 g
- 5-year warranty
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.5 mm
- 7 mm
- 59.7 g
Performance
- SSD Endurance
- 320 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 545 MBps (read) / 520 MBps (write)
- 4KB Random Read
- 95000 IOPS
- 4KB Random Write
- 75000 IOPS
Reliability
- MTBF
- 1,750,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 70 mW (average) , 2850 mW (read) , 4400 mW (write)
- UL, TUV, VCCI, BSMI, FCC, KC
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms half-sine pulse
- Shock Tolerance (non-operating)
- Vibration Tolerance (operating)
- 5 g @ 10-2000 Hz
- Vibration Tolerance (non-operating)
- 4.9 g @ 7-800 Hz
