Sandisk Ultra USB 3.0 Flash Drive 32GB
Quicklinx: 92JLWS00 Mfr#: SDCZ48-032G-U46
Capacity: 32GB
Interface: USB 3.0
£4.51 ex VAT
£5.41 inc VAT
Get to Your Files Faster
The SanDisk Ultra USB 3.0 Flash Drive combines faster data speeds and generous capacity in a compact, stylish package. With transfer speeds of up to 80MB/s, this USB 3.0 flash drive can move files up to four times faster than USB 2.0 drives**Read speeds up to 4 times faster than Cruzer® USB 2.0 drives at up to 80MB/sec. USB 3.0 port required. Based on internal testing using a USB 3.0 compatible host; performance will vary depending on host device. 1MB=1,000,000 bytes.. With storage capacities up to 64GB, the drive can accommodate your bulkiest media files and documents.
  • Fast transfer speeds up to 80MB/s**Read speeds up to 4 times faster than Cruzer® USB 2.0 drives at up to 80MB/sec. USB 3.0 port required. Based on internal testing using a USB 3.0 compatible host; performance will vary depending on host device. 1MB=1,000,000 bytes.
  • Transfer files up to four times faster than USB 2.0 drives **Read speeds up to 4 times faster than Cruzer® USB 2.0 drives at up to 80MB/sec. USB 3.0 port required. Based on internal testing using a USB 3.0 compatible host; performance will vary depending on host device. 1MB=1,000,000 bytes.
  • Capacities up to 64GB**1 GB=1,000,000,000 bytes. Actual user storage less.
  • Protect private files with SanDisk SecureAccess™ software**Password protection uses 128-bit AES encryption and is supported by Windows® XP, Windows Vista®, Windows 7, Windows 8, and Mac OS X v10.5+ (Software download required for Mac, see www.SanDisk.com/SecureAccess)
  • USB 3.0-enabled and USB 2.0-compatible
Move Files Quickly with Faster Transfer Speeds
With transfer speeds of up to 80MB/s**Read speeds up to 4 times faster than Cruzer® USB 2.0 drives at up to 80MB/sec. USB 3.0 port required. Based on internal testing using a USB 3.0 compatible host; performance will vary depending on host device. 1MB=1,000,000 bytes., the SanDisk Ultra USB 3.0 Flash Drive reduces the time you'll spend waiting for files to move from the flash drive to your computer. Enabled for USB 3.0 ports, the drive lets you transfer, store, and share large files up to four times faster than USB 2.0 drives**Read speeds up to 4 times faster than Cruzer® USB 2.0 drives at up to 80MB/sec. USB 3.0 port required. Based on internal testing using a USB 3.0 compatible host; performance will vary depending on host device. 1MB=1,000,000 bytes..
High-Capacity Drive Accommodates Large Files
Offered in capacities up to 64GB**1 GB=1,000,000,000 bytes. Actual user storage less., the SanDisk Ultra USB 3.0 Flash Drive can hold all your favorite media and important documents, including high-resolution photos, MP3s, HD**HD (1280x720) video support may vary based on host device, file attributes and other factors. See www.sandisk.com/HD movies, presentations, and graphic files.
Stylish, Portable Design
With its sleek black design, the SanDisk Ultra USB 3.0 Flash Drive is as stylish as it is practical. This compact and portable drive can easily travel with you in a pocket or handbag.
SanDisk SecureAccess Software Keeps Files Private
The SanDisk Ultra USB 3.0 Flash Drive includes SanDisk SecureAccess software, which lets you set up a password-protected private folder on your drive**Password protection uses 128-bit AES encryption and is supported by Windows® XP, Windows Vista®, Windows 7, Windows 8, and Mac OS X v10.5+ (Software download required for Mac, see www.SanDisk.com/SecureAccess). Your files will be secured with 128-bit AES encryption to help keep them confidential, even when sharing the drive with others.
Warranty
The SanDisk Ultra USB 3.0 Flash Drive is backed by a five-year limited warranty**See www.sandisk.com/wug for additional information..
  • Move Files Quickly with Faster Transfer Speeds
    With transfer speeds of up to 100MB/s, the SanDisk Ultra USB 3.0 Flash Drive reduces the time you'll spend waiting for files to move from the flash drive to your computer. Enabled for USB 3.0 this fast drive lets you transfer and store large files up to ten times faster than standard USB 2.0 drives.
  • High-Capacity Drive Accommodates Large Files
    Offered in capacities up to 256GB, the SanDisk Ultra USB 3.0 Flash Drive can hold all your favorite media and important documents, including high-resolution photos, MP3s, movies, presentations, and graphic files.
  • Stylish, Portable Design
  • SanDisk SecureAccess Software Keeps Files Private
    The SanDisk Ultra USB 3.0 Flash Drive includes SanDisk SecureAccess software, which lets you set up a password-protected private folder on your drive . Your files will be secured with 128-bit AES encryption to help keep them confidential, even when sharing the drive with others.
  • Warranty
    The SanDisk Ultra USB 3.0 Flash Drive is backed by a five-year warranty .
SanDisk Ultra - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Encryption Algorithm
128-bit AES
Europe
Software Included
SanDisk SecureAccess, SanDisk RescuePRO
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Windows 8
Microsoft Certification
Compatible with Windows 7
5-year warranty
USB flash drive
Storage Capacity
32 GB
128-bit AES
Europe
Read Rate
Up to 130 MB/s
Write Rate
Up to 60 MB/s
Interface Type
USB 3.0
Password protection, retractable connector, key ring loop
AES-128
Software Included
Limited warranty - 5 years
21.3 mm
56.8 mm
10.8 mm
9 g
Shipping Width
101.6 mm
Shipping Depth
152.4 mm
Shipping Height
11.9 mm
Shipping Weight
32.8 g
45 °C
Capacity: 32GB
Interface: USB 3.0
Brand: Sandisk
