The faster you can transfer content, the faster you can start having fun – or the faster you can get your work done. The 16GB SanDisk Ultra USB 3.0 Flash Drive offers ultra-fast read speeds of up to 80MB/sec . This means that you can transfer large HD videos, photos and other files in just a fraction of the time USB 2.0 technology can support. It also includes SanDisk SecureAccess software with 128-bit file encryption and password protection so that even your largest private files stay protected, yet you can still share the files you want to.
                Move Files Quickly with Faster Transfer SpeedsWith transfer speeds of up to 100MB/s, the SanDisk Ultra USB 3.0 Flash Drive reduces the time you'll spend waiting for files to move from the flash drive to your computer. Enabled for USB 3.0 this fast drive lets you transfer and store large files up to ten times faster than standard USB 2.0 drives.
                High-Capacity Drive Accommodates Large FilesOffered in capacities up to 256GB, the SanDisk Ultra USB 3.0 Flash Drive can hold all your favorite media and important documents, including high-resolution photos, MP3s, movies, presentations, and graphic files.
                Stylish, Portable DesignWith its sleek black design, the SanDisk Ultra USB 3.0 Flash Drive is as stylish as it is practical. This compact and portable drive can easily travel with you in a pocket or handbag.
                SanDisk SecureAccess Software Keeps Files PrivateThe SanDisk Ultra USB 3.0 Flash Drive includes SanDisk SecureAccess software, which lets you set up a password-protected private folder on your drive . Your files will be secured with 128-bit AES encryption to help keep them confidential, even when sharing the drive with others.
                WarrantyThe SanDisk Ultra USB 3.0 Flash Drive is backed by a five-year warranty .
- SanDisk Ultra - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 16 GB
- Encryption Algorithm
- 128-bit AES
- Localisation
- Europe
- Software Included
- SanDisk SecureAccess, SanDisk RescuePRO
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Windows 8
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- 128-bit AES
- Localisation
- Europe
- Read Rate
- Up to 130 MB/s
- Interface Type
- USB 3.0
- Password protection, retractable connector, key ring loop
- AES-128
- Software Included
- OS Required
- Limited warranty - 5 years
- 21.3 mm
- 56.8 mm
- 10.8 mm
- 0 °C
- 45 °C
